Distinguishing between Raw Egg and Hard-Boiled Egg
  • Thread starter Thread starter andyrk
    Egg
The discussion centers on the physics behind the spinning behavior of raw and hard-boiled eggs, specifically examining the roles of moment of inertia, angular velocity, and conservation of angular momentum. A hard-boiled egg spins faster due to its rigid structure, while a raw egg spins longer because the liquid inside continues to move independently, affecting its overall motion. Observations indicate that the mass distribution and internal dynamics of the egg significantly influence its spinning characteristics. Practical experimentation with eggs is encouraged to better understand these principles.
  • Understanding of moment of inertia
  • Knowledge of angular velocity
  • Familiarity with conservation of angular momentum
  • Basic principles of rigid body dynamics
  • Research the concept of moment of inertia in detail
  • Explore angular velocity and its effects on rotating bodies
  • Study conservation of angular momentum in various physical systems
  • Conduct experiments with spinning objects to observe real-world applications
Physics students, educators, and anyone interested in the mechanics of motion and rotational dynamics will benefit from this discussion.
andyrk
Why does a hard-boiled egg spin faster than a raw egg?
Why does a raw egg spin longer than a hard-boiled egg?
Can this be explained using moment of inertia, angular velocity and conservation of angular momentum?
Or can this be explained only on the basis of the liquid inside the raw egg which keeps on rotating and thus makes the raw egg rotate longer and as it opposes/slides against the inside of the shell, it slows down the egg?
It is about the difference between the way gooey stuff responds vs how a rigid body responds - also about the mass distribution inside the egg, and the interaction between rigid and gooey stuff.
You have to break down the process involved in each test ... how do the different parts of the egg respond to attempts to change the motion.
It is also hard to spin a raw egg on it's point, and if you touch a hard-boiled egg that is spinning rapidly on it's side so it stops, but very quickly release it, it will resume spinning.
Note: if you have never seen these effects, you should get some eggs and try it. Careful observation will (should) help with your answers.
Clearly that is not a general rule. It must assume something constant about the circumstances. Was there any more text to the question?
For this one, it may be the same presumed constant circumstance, or maybe this is assuming the same initial spin rate. Either way, I do not believe the statement is true.
What does happen is that if you stop the spinning egg and immediately let go again, the raw egg will resume turning.
http://www.planet-science.com/categories/experiments/magic-tricks/2012/03/spinning-eggs.aspx
Admittedly I havn't seen the second one either and I think it refers to the stop-release method.
Didn't get that much. Could you please provide a more detailed explanation? If the moment of inertia of of the raw egg increases, how does it effect the velocity with which it rotates?
Um, no, the idea is that you do the work.
But it is not entirely about the moment of inertia of the whole egg - but about the different parts, where they are, and how they are connected together.
  • · Replies 30 ·
15K
16K
