Divergence of the geometric Series at r=1
The geometric series diverges at r=1, as demonstrated through the limit process and the evaluation of the series itself. The Nth partial sum is expressed as S_n = r(1-r^n)/(1-r), which converges for 01. At r=1, the series becomes S = 1 + 1 + 1 + ... which does not yield a finite value, confirming divergence. The confusion around the 0/0 form is clarified by recognizing that this limit approaches infinity, reinforcing the divergence of the series.
  • Understanding of geometric series and their properties
  • Familiarity with limits and convergence concepts
  • Basic knowledge of mathematical notation and summation
  • Ability to manipulate algebraic expressions involving series
  • Study the concept of limits in calculus, particularly L'Hôpital's Rule
  • Explore the convergence criteria for series, focusing on the Ratio Test and Root Test
  • Learn about the behavior of series at boundary values, specifically for geometric series
  • Investigate the implications of divergent series in mathematical analysis
Mathematics students, educators, and anyone interested in series convergence, particularly those studying calculus or mathematical analysis.
sid9221
Now for the proof of convergence/divergence of the geometric series we first deduce the Nth partial sum which is given by:
\frac{r(1-r^n)}{1-r}
Now for 0<r<1 this become \frac{1}{1-r} which clearly converges by AOL
At r>1 it's similarly obvious why it diverges.
But at r=1, I'm a bit confused. The text say's that it diverges but when I try to work it out I get:
1^n -&gt; 1
S_n = \frac{C*0}{1-1}
which measn S_n = 0 which is confusing as it seems to indicate convergence ?
Am I suppose to interpret 0/0 as implying divergence ?
For a geometric series, |r|<1 for convergence. If r has any other value, including 1 and -1, the series diverges.
If you find the limit at r=1, you will get a/(1-1)=a/0=∞, hence the series diverges.
1^n -&gt; 1
You are supposed to avoid 0/0 like the plague. The point is that in the LIMIT as r --> 1, the sum r/(1-r) --> infinity. Of course, you can also write down the sum directly when r = 1, to see that S = 1 + 1 + 1 + 1 + ... does not have a finite value.
RGV
What you should learn from this is "Don't just use formulas thoughtlessly- think!
If r= 1, then the sum is \sum_{i=0}^\infty a(1)^n= a+ a+ a+ \cdot\cdot\cdot. The nth partia series is na so that clearly does not converge.
If r= -1, then the sum is \sum_{i= 0}^\infty a(-1)^n= a- a+ a- a+ \cdot\cdot\cdot. The nth partial series is a if n is odd, 0 if n is even so, again, that does not converge.
  • · Replies 17 ·
