Divergence Theorem: Check Function w/y^2, 2x+z^2, 2y
9 replies · 3K views · last reply
vorcil
Check the divergence theorem using the function:
[tex]\mathbf{v} = y^2\mathbf{\hat{x}} + (2xy + z^2) \mathbf{\hat{y}} + (2yz)\mathbf{\hat{z}}[/tex]
[tex]\int_\script{v} (\mathbf{\nabla . v }) d\tau = \oint_\script{S} \mathbf{v} . d\mathbf{a}[/tex]
taking the dot product it becomes
[tex]\frac{\partial}{\partial x} y^2 \mathbf{\hat{x}} + \frac{\partial}{\partial y} ( 2xy + z^2) \mathbf{\hat{y}} + \frac{\partial}{\partial z} (2yz)\mathbf{\hat{z}}[/tex]
so by only differentiating the certain parts:
i get y^2 + 2x + z^2 + 2y,
however the dot product of del and my vector v, should've been 2(x+y)
how come I've got y^2 and z^2?
does [tex]\frac{\partial}{\partial x} y^2[/tex] not equal y^2?
Your divergence should not actually include any vectors. It's just a number. So you should have
[tex] \frac{\partial}{\partial x} y^2 + \frac{\partial}{\partial y} ( 2xy + z^2) + \frac{\partial}{\partial z} (2yz)[/tex]
Once you take the dot product
Then it looks like you differentiated your unit vectors as though they were variables
[tex]\frac{\partial}{\partial x} y^2[/tex] is 0, not y2
this isn't correct, you applied a dot product, it should be
[tex]\frac{\partial}{\partial x} y^2 + \frac{\partial}{\partial y} ( 2xy + z^2) + \frac{\partial}{\partial z} (2yz)[/tex]
to see where you went wrong, what is
[tex]\frac{\partial}{\partial y} z^2[/tex]
Is it 0? is that because z^2 is a constant since it's being differentiated with respect to y?
and d/dx of a constant is 0?
now knowing that [tex]\frac{\partial}{\partial y} z^2 = 0[/tex]
I think I can solve the rest,
[tex] \int_\script{v} (\mathbf{\nabla . v }) d\tau = \oint_\script{S} \mathbf{v} . d\mathbf{a} [/tex]
so
[tex]\oint_{\script{V}} 2(x+y) d\tau[/tex]
taking the constant out and making tau dxdydz = [tex]2 \int_0^1 \int_0^1 \int_0^1 (x+y) dxdydz[/tex]
separating the three integrals out, (i think I can do that?)
dx part: [tex]\int_0^1 (x+y)dx = \left[ \frac{x^2}{2}+y \right]_0^1 = (\frac{1}{2} + y)[/tex]
dy part, using the result of the dx part:
[tex]\int_0^1 (\frac{1}{2} + y) dy = \left[ \frac{1}{2} + \frac{y^2}{2} \right]_0^1 = (\frac{1}{2} + \frac{1}{2})[/tex]
dz part using the result of the dy part:
[tex]\int_0^1 (1)dz = \left[ 1*z\right]_0^1 = 1[/tex]
bringing in the constant 2, of what I brought outside the integral,
[tex]\int_{\script{V}} \mathbf{\nabla . v} d\tau = 2[/tex]
so that means the integral of a derivative over the vector is equal to 2,
and to confirm the divergence theorem,
I also need to integrate over a closed surface for the cube?
that means i need to solve for 6 integrals,
yes that is the definition of a partial derivative, the other variables are held constant
It does indeed require you to compute 6 double integrals over the surface of the unit cube.
not sure why you would separate it, anyway though you get the right answer (luck), the integral isn't correct. y is treated as a constant, what is the integral of a constant?
oh right, I should've separated and differentiated each bit individually,
so \int x dx, |_0^1
then added \int y dy |_0^1 to it
and then multiplied by int dz,
just treat it as
[tex]2 \int_0^1 \left(\int_0^1 \left(\int_0^1 (x+y) dx\right)dy\right)dz[/tex]
