Dividing with indices resulting in incorrect sign
  • Thread starter Thread starter Dickie
    Indices Sign
4 replies · 2K views
Dickie
Simplify [(-2t)^3] / [(-4t)^2] and evaluate (-2/3)^-2
1/m^n = m^-n
I am able to simplify/evaluate the above equations correctly, however I end up with an incorrect sign for each answer (i.e positive when it should be negative) and I can't see where the error is. I feel I am clearly missing something but having checked my working including with a calculator for the basic arithmetic (to check the signs) I am none the wiser as to what I am actually getting wrong. Below are my workings:
= [(-2t)^3] / [(-4t)^2]
= [-8t^3] / [-16t^2]
= 1/2t
I am basing this on -8 / -16 = 1/2 and (t^3)/(t^2) = t, although the answer I am provided gives -1/2t which is leading to my confusion. I have also tried beginning with [(-2t)^3)] * [(-4t)^-2] giving [-8t^3] * [-1/16t^-2] however still end up with the same result.
= (-2/3)^-2
= (-2^1 * 3^-1)^-2
= (-2^-2 * 3^2)
= -1/4 * 9
= -9/4
However, again the answer provided is the opposite sign (in this case 9/4).
Looking back, my confusion is to do with a negative divided by a negative vs a negative fraction. So, if -(2/3) = (-2/3) = (-2/-3) [apologies, I can't think of a clearer way of explaining this] then I'd expect:
= -8 / -16
= -(8 / 16) = -8 / 16
= -1/2 which would give me the correct answer for the first question.
In that case I'd expect:
= (-2/3)
= -(2/3) = (-2 / -3)
So:
= (-2^1 * -3^-1)^-2
= -1/4 * -9
= 9/4
Is this then the correct logic I should be using?
Dickie said:
Homework Statement:: Simplify [(-2t)^3] / [(-4t)^2] and evaluate (-2/3)^-2
Relevant Equations:: 1/m^n = m^-n
= 1/2t
= (-2/3)^-2
= (-2^1 * 3^-1)^-2
= (-2^-2 * 3^2)
= -1/4 * 9
= -9/4
What is (−4)2 ?
What is (−2)2 ?
So, in answering your question I've realized the following:
(-4)^2 = 16
-4^2 = -16
This seems to be the source of my confusion for the first question, so thank you. This also seems to apply for the second question where I think I should have used:
(-2)^-2 = 1/4
Thanks again - I thought it would be something simple I'd missed!
(-4)^2 = 16
-4^2 = -16
This seems to be the source of my confusion for the first question, so thank you. This also seems to apply for the second question ...
Yes.
Remember the fundamentals.
(−2t)^2 is shorthand for (−2t)×(−2t) , which is 4×t^2
Thanks again, I always find it's the basics which trip me up.
I'm returning to study in my 30s for an MSc and have been given these questions as part of some pre-course work to do to refresh my maths - despite having done well at maths in the past, it turns out there are more than a few gaps in my knowledge now!
