Divisibility Challenge: Find Smallest Integer for $f(x)$
lfdahl
MHB
Let $f(x) = 5x^{13}+13x^5+9\cdot a \cdot x$
Find the smallest possible integer, $a$, such that $65$ divides $f(x)$ for every integer $x$.
Finally, some abstract algebra pays off!
[sp]First of all, note that $65|(5x^{13}+13x^5 + 9ax) \iff 5|(5x^{13}+13x^5 + 9ax)$ and $13|(5x^{13}+13x^5 + 9ax)$.
This suggests looking at the given polynomial mod 5 and mod 13.
Mod 5 we have:
$3x^5 + 4ax = 0$ (since we want 5 to divide the expression on the left).
$x(3x^4 + 4a) = 0$
Since $x$ can be some integer co-prime to 5, we will assume $x \neq 0$ (mod 5). Thus:
$3x^4 + 4a = 3 + 4a = 0$, that is:
$4a = 2$ (mod 5) so that:
$a = 3$ (mod 5).
Mod 13 we have:
$5x^{13} + 9ax = 0$ (since we want the expression on the left to be divisible by 13), thus:
$x(5x^{12} + 9a) = 0$. Again, we may assume $x \neq 0$ (mod 13), so we have:
$5x ^{12} + 9a = 5 + 9a = 0$ thus:
$9a = 8$ (mod 13), so that:
$a = 11$ (mod 13).
Since 5 and 13 are prime, we can apply the Chinese Remainder theorem to obtain:
$a = (3)(13)[13^{-1}]_5 + 11(5)[5^{-1}]_{13} = (3)(13)(2) + (11)(5)(8) = 78 + 440 = 518 = 65*7 + 63 = 63$ (mod 65).
Depending on if you meant:
the smallest POSITIVE value for $a$, we obtain: $a = 63$
the smallest absolute value for $a$, we obtain $a = -2$
there is no "smallest" such $a$ given the usual ordering of the real numbers, since the set of solutions contains infinitely many negative integers.[/sp]
$f(x) = x(5x^{12} + 13x^4 + 9a)$
x can be factored out so 65 should divide $5x^{12} + 13x^4 + 9a$
65 = 13 * 5
So taking mod 5 we have $13x^4\, + 9a\, mod\, 5 = 0$
It is true for any x so take x co-prime to 5 so we have x^4 = 1
So we get 13 + 9a mod 5 = 0 or 3 – a mod 5 = 0 or a = 3 mod 5
Similarly we have $5x^{12} + 9a \,mod \,13 = 0$ or 5 + 9a mod 13 = 0 or a = 11 mod 13
a = 3 mod 5 and a = 11 mod 13 can be solved by using chinees remainder theorem also but we see that
a = -2 mod 5 and a = -2 mod 13 so a = -2 mod 65 or 63
a = 63 + 65n and a = 63 is the lowest positive integer
Thankyou and well done Deveno and kaliprasad for your thorough and correct answers.
You´re absolutely right, Deveno, I should have pointed out, that it is the smallest positive integer a, I was looking for.
Solution by other:
\[f(x)\equiv 0 \: \: \: (mod\: \: \: 65)\\\\ 5\cdot x^{13}+13\cdot x^5+9\cdot a\cdot x \equiv 0 \: \: \: (mod\: \: \: 65)\\\\\]
Applying "Fermats little theorem":
\[5\cdot x^{13}\equiv 5x \: \:\: (mod\: \: \: 65)\\\\ 13\cdot x^{5}\equiv 13x \: \:\: (mod\: \: \: 65)\\\\\]
\[5x + 13x + 9ax \equiv 0 \: \:\: (mod\: \: \: 65)\\\\ 9x(2+a)\equiv 0\: \:\: (mod\: \: \: 65)\\\\\]
Thus
$$2+a\equiv 0\: \:\: (mod\: \: \: 65) \Rightarrow a = 63$$
