MHB Proving Divisibility of Polynomials in Field Extensions
In the discussion, the goal is to prove that if a polynomial \( g \) divides another polynomial \( f \) in a field extension \( K \), then \( g \) also divides \( f \) in the base field \( F \). The approach involves applying the division algorithm to express \( f \) as \( f = gq + r \) in \( F[X] \), where \( r \) is the remainder. Given that \( g \mid f \) in \( K[X] \), it follows that \( r \) must equal zero, leading to the conclusion that \( g \mid f \) in \( F[X] \). The reasoning is validated through a contradiction regarding the degrees of the polynomials involved. The proof is sound and effectively demonstrates the divisibility in both fields.
mathmari
MHB
Hey! :o
Let $K/F$ be a field extension, $f,g\in F[X]$. I want to show that if $g\mid f$ in $K[X]$, then $g\mid f$ also in $F[X]$.
Suppose that $g\mid f$ in $K[X]$. Then $f=g\cdot h$, where $h\in K[X]$. We have to show that $h\in F[X]$.
Could you give me some hints how we could show that? (Wondering)
mathmari said:
Hey! :o
Hint: Use division algorithm for the polynomials $f$ and $g$ in $F[x]$.
Applying the division algorithm for the polynomials $f$ and $g$ in $F[x]$, we have $$f=gq+r$$ where $q,r\in F[x]$ with $\deg g>\deg r$.
We have that $g\mid f$ in $K[x]$, so $f=gh$, where $h\in K[x]$.
Therefore, we have the following:
$$r=f-gq=gh-gq=g(h-q)$$
We have that $g\neq 0$.
So, if $r\neq 0$ then $h-q\neq 0$. We have that $$\deg r=\deg (g(h-q))=\deg g+\deg (h-q)>\deg r+\deg (h-q) \Rightarrow \deg (h-q)<0$$ a contradiction.
Therefore, it must be $r=0$, i.e., $f=gq$ in $F[x]$, i.e., $g\mid f$ in $F[x]$.
Is everything correct? Could I improve something? (Wondering)
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 24 ·
  • · Replies 16 ·
