Division algorithm in A[x] (A NOT a field)
2 replies · 2K views
sidm
is it possible? I'm reading a proof where A is a local ring and f is a monic polynomial, v another polynomial in A[x] then the author says there is q,r with v=qf+r and degf<r.
I thought the algorithm required divison of coefficients?! Maybe it's true we can always do this with f monic?
thanks
I'm assuming you mean to require deg r < deg f (not the other way around).
No division of coefficients is required as long as f is monic (you don't need that A is local either). If f has degree larger than v you can just let r=f, q=0. Thus you can assume [itex]deg(f) \leq deg(v)[/itex]. Let (v,f) be a pair of polynomials for which no such division exists, and for which the degree of v is minimal.
If deg v = 0, then deg f = 0 and since f is monic f=1 so we can let q=v, r=0.
If deg v > 0 let:
[tex]h(x) = v(x) - Ax^{\deg(v) - \deg(f)}f(x)[/tex]
where A is the coefficient of the term of highest degree in v(x). Then deg h < deg v and therefore we can divide h by f to give it polynomials q(x) and r(x) with deg r < deg f such that:
[tex]h(x) = q(x)f(x) + r(x)[/tex]
so
[tex]v(x) = (q(x)+Ax^{\deg(v) - \deg(f)})f(x) + r(x)[/tex]
which shows that division is possible.
ahhh, this is a good fact to know, much appreciated!
