AlMetis
- Messages
- 98
- Reaction score
- 7
I agree.Nugatory said:A frame is a convention for attaching numerical labels (for example, x,y,z and t coordinates) to events. Therefore, using a different frame can only change the labels attached to the events, not the events themselves. Light hitting the mirror is an event.
That’s why.
I have included another diagram that is (hopefully) less ambiguous than the word salads I’ve been posting.
The diagram plots the Galilean transformation of the same motion of source, mirror and light predicted to be observed by two inertial frames in motion.
The relativistic (Lorentz) transformations which hold the constancy of c in both frames, removes the (apparent) conflict of “different events” observed by each frame predicted by Galilean relativity. To remove the conflict, the slower time of the moving frame (S from E’s frame) allows it to measure a shorter length S-A of longer light path S-c+3v which holds S’s measure of light speed at c.
In other words, the shorter you measure a longer path, the slower your time must run to arrive at the same ratio of d/t = c.
