JimWhoKnew
- 270
- 158
Even if you ignore the gravitational field of Schwarzschild BH, a Reissner-Nordstrom BH has EM field all the way to the singularity.PeterDonis said:it's vacuum.
Which is just your handwaving. You have given no math showing "dying of the field".JimWhoKnew said:The dying of the field
No, no "hair" can be back scattered into the hole, because then it would be "hair" that the hole would have that it can't have by the no hair theorem.JimWhoKnew said:the hair doesn't have to be completely radiated away. Some of it can be back-scattered into the hole.
The way the math says they do.JimWhoKnew said:How do electromagnetic fields actually work?
There is no such thing as a "gravitational field" in GR apart from the spacetime geometry. A Schwarzschild BH is pure spacetime geometry, i.e., vacuum.JimWhoKnew said:Even if you ignore the gravitational field of Schwarzschild BH
Yes, for the charged case "electrovacuum" is the strictly correct term. But there is still no "location" that has any charge. We attribute a charge to the hole because it has a Coulomb field that is externally measurable.JimWhoKnew said:a Reissner-Nordstrom BH has EM field all the way to the singularity.
Has already been referred to in this thread, namely, Kip Thorne's description referenced in post #16 (which, as noted in that post, is based on published peer-reviewed literature).JimWhoKnew said:a good qualitative description
This paper calculates the magnetic field due to a current loop in the external Schwarzschild spacetime. The ratio of the leading order magnetic dipole moment between the case in which the loop is positioned in ##r_1## and the case where it is in ##r_2## is approximated by$$\frac{^1 B_i(r)}{^2 B_i(r)}\approx\frac{I_1 r_1^2 \sqrt{1-\frac{2 m}{r_1}}}{I_2 r_2^2 \sqrt{1-\frac{2 m}{r_2}}} \quad .$$When ##r_1\approx r_2 \approx 2 m## , it is in accord with my hand waiving in #26.PeterDonis said:Which is just your handwaving. You have given no math showing "dying of the field".
Box 32.2 in MTW discusses Price's theorem. It says:PeterDonis said:No, no "hair" can be back scattered into the hole,
All I have to say in response is written in subsections A.6-A.9 of box 32.2 in MTW (too long to quote), and in the other subsections of that box.PeterDonis said:because then it would be "hair" that the hole would have that it can't have by the no hair theorem.
Yes, Black Holes and Time Warps also says that the EM radiation may go inwards into the hole. I think possibly just your wording "the hair doesn't have to be completely radiated away" (post #29) may be confusing, as it can be read as meaning that the black hole can still have hair at the end of the process. The hair all converts into radiation (or at least, something that can flow) and goes away, but some of the energy in the hair may go inwards into the hole and end up contributing to one of the non-hairy parameters.JimWhoKnew said:Box 32.2 in MTW discusses Price's theorem. It says:
"Price's theorem states that, as the nearly spherical star collapses to form a black hole, all things that can be radiated get radiated completely away - in part "off to infinity"; in part "down the hole"."
None of these contradict what I said, or support your claim that "hair" such as a magnetic field can be radiated down the hole and become a property of a stationary hole. As I said, that would contradict the no hair theorem.JimWhoKnew said:subsections A.6-A.9 of box 32.2 in MTW
I claimed that?PeterDonis said:your claim that ... and become a property of a stationary hole.
I think you can read #29 that way, although I don't think you intended it so.JimWhoKnew said:I claimed that?
The "hair" being back-scattered into the hole would mean it becomes a property of the hole. Perhaps what you intended is what @Ibix said in post #36, but if so, that was not at all clear.JimWhoKnew said:the hair doesn't have to be completely radiated away. Some of it can be back-scattered into the hole
Yet, my understanding from the literature is that although hair can't fall into the hole to become a permanent property, it is not ruled out as a transient property.Ibix said:I think you can read #29 that way, although I don't think you intended it so.
Yes. If you read my previous posts where I talk about the no hair theorem, you will note that I say it is true for a stationary black hole. During the transient condition, the hole is not stationary.JimWhoKnew said:although hair can't fall into the hole to become a permanent property, it is not ruled out as a transient property.
It can't be a perfect Schwarzschild BH if an object is falling in, since the object affects the spacetime geometry.JimWhoKnew said:Suppose an object falls radially (zero charge, zero angular momentum) into a perfect Schwarzschild BH.
First, mass is already a property that a stationary black hole can have, so the "hair" question is irrelevant for it. (So are charge and angular momentum, so the same would apply if you postulated a charged object with nonzero angular momentum falling into a Kerr-Newman black hole.)JimWhoKnew said:Between the crossing of the horizon and the crash at the singularity, would you consider it as hair?
