Do black holes swallow dark matter?
Black holes do not significantly consume dark matter due to its low density in galactic centers and its weak interaction with normal matter. While dark matter contributes to gravitational effects, it primarily orbits black holes rather than being absorbed. Theoretical discussions suggest that dark matter's lack of friction prevents it from forming accretion disks, making it difficult for dark matter to enter black holes. Current observations indicate that dark matter comprises less than 10% of the mass accreted by black holes, confirming its minimal impact on black hole growth.
  • Understanding of black hole physics and accretion processes
  • Familiarity with dark matter properties and its gravitational effects
  • Knowledge of galactic structure and density distributions
  • Basic concepts of particle interactions and thermal distributions
  • Research the role of dark matter in galaxy formation and structure
  • Explore the implications of dark matter annihilation in astrophysics
  • Investigate observational methods for detecting dark matter interactions
  • Study the dynamics of accretion disks around black holes
Astronomers, astrophysicists, and researchers interested in the interactions between black holes and dark matter, as well as those studying galaxy formation and cosmic structure.
Naty1
What do we know about black holes swallowing dark matter? Dark matter exhibits gravitational effects, right [lensing and keeping star orbital speeds about galactic centers rouighly independent of their distance from a galactic center]? So it seems black holes should consume both normal and dark matter.
Are there any theoretical ways to detect the effects of dark matter when it's consumed by black holes?? Anyone seen any discussions or papers?? Thanks?
Space news on Phys.org
Anything that is consumed by a black hole will add to the mass, charge, and angular momentum. Otherwise there is nothing to to identify it. In particular, dark matter and normal matter cannot be distinguished after being consumed by a black hole.
Not to mention that there is a minuscule amount of dark matter in the galactic centre, where black holes are "swallowing matter", compared to the amount of baryonic matter.
Yes. And more important than that, dark matter doesn't experience much of any friction. This means that even if some dark matter gets in the vicinity of a black hole, it tends to just blow on by. It has to actually strike the black hole to go into it (and black holes are pretty darned small for their mass, so hitting one is difficult).
This is contrasted to normal matter which, through friction, enters an accretion disk around the black hole, a disk that slowly collapses into the black hole through loss of energy from friction.
All valid points in the above posts...yet with dark matter making up such a large proportion of all matter seems like it could have an effect...maybe somehow we could observe effects.
Chalnoth...interesting observation
I'm guessing Hawking work on radiation did not reflect any dark matter ingestion...but I wonder if it could be expanded/modified to do so.
The problem is that the dark matter, within the galaxy, is at a much lower density than the normal matter. Most of the dark matter is in a "halo" that surrounds the galaxy. This isn't to say it's more dense out there, it's just a statement that the normal matter collapses through friction to form the galaxy, while the dark matter more or less stays in its orbit at after it first becomes gravitationally bound to the galaxy.
So no, I don't think there would be much of an observable effect.
The closest thing to this suggestion that I've seen is that because of the fact that normal matter is so much more dense, it's going to attract some amount of dark matter to it. With more dark matter comes more annihilations (dark matter is expected to be made up of equal parts matter and anti-matter, because it must interact too weakly to have annihilated in the early universe to have the properties we observe). Dark matter annihilations are expected to be one observable signal we could potentially use to understand its properties.
One attempt at observing annihilating dark matter comes from WMAP observations:
http://arxiv.org/abs/0802.3830
At this point, I would place this observation of the WMAP haze at speculative at best. But at least it serves as a model of how one might go about observing dark matter directly.
I don't think it makes any difference whatsoever.
Only when they are on a diet.
:cool:
This is a question for me. Dark matter would orbit the center of mass. But since it does not interact much it would just pass to the other side without interaction. I have to think, though, that there would still be a much greater density of DM at the center than at the edges simply because the gravitational field is stronger there. Sure it would be traveling faster, but there would be more of it. Perhaps there could be a greate enough density of DM to form a BH.
Yes, the density of dark matter is expected to be larger near the galactic center. Not enough to make the density outweigh the normal matter, but still larger than it is outside the galaxy (if we define the galaxy as the normal matter part). As far as I'm aware, however, our observations of dark matter are not yet accurate enough to confirm this. But it is definitely expected from theory.
Dark matter is not interactive with normal matter. It would pass right through a black hole. See the bullet cluster paper.
Huh?
Nothing passes right through a black hole.
It gravitates (that's how we know it's there). It would therefore be captured by a BH in exactly the same way as normal matter.
If we have already established that DM can develop pockets of larger density when before it was an even distribution, then the question is why can't it become even denser and form BHs made only of DM. If it can become dense to begin with, then what's to stop it from becoming even denser?
In principle it might, but the time scale for such a thing would be exceedingly long. The reasoning is as follows:
1. To form a black hole, you need a local overdensity of dark matter so great that it prevents the dark matter from escaping. The magnitude of this overdensity is vastly above the typical average density of dark matter within a galaxy or galaxy cluster.
2. In order to get such a massive overdensity, you need the orbits of the dark matter particles in a potential well to decay. This can only be done through friction.
3. Dark matter experiences almost no friction.
If you make the assumption of perfectly non-interacting dark matter, I'm sure you could calculate just how long this would take. Given our observations, this time scale must be many times the current age of the universe (because if it weren't, dark matter would have collapsed noticeably by now: it hasn't).
However, this may well turn out not to work for real dark matter, because real dark matter is likely to have some interaction. In particular, it is likely to be nearly equal parts matter and anti-matter, meaning that any significant overdensity of dark matter will also be very efficient at causing the dark matter particles to annihilate, likely causing the structure to evaporate long before it gets dense enough to form a black hole.
When normal matter collapses, it loses energy through radiation, which tends to hasten collapse. Dark matter doesn't do this. Consequently: 1) normal matter forms black holes more easily; 2) black holes present larger effective targets to normal matter than they do to dark matter.
A quote from Weinberg's new cosmology book:
Weinberg said:
Of course, eventually the perturbations in the matter density became strong enough for the linear approximation to break down, as shown vividly be the existence of stars and galaxies and galaxy clusters. It is believed that these structures were formed in a two-step process.1 First, in regions where the density was a little larger than average, the cold dark matter and the baryonic matter together expanded more slowly than the universe as a whole, eventually reaching a minimum density and then recontracting. This scenario is discussed in section 8.2. If an overdense region was sufficiently large then as shown in 8.3 its baryonic matter collapsed along with its cold dark matter. Then in a second stage, after this collapse, the baryonic matter lost its energy through radiative cooling, and it condensed protogalaxies consisting of clouds of gas that eventually form stars. The cold dark matter particles could not lose their energy through radiative cooling, so they remained in large more-or-less spherical halos around these galaxies.
1S. D. M. White and M. J. Rees, Mon. Mot. Roy. Astron. Soc. 183 341 (1978)
[EDIT]Chalnoth posted much the same stuf while I was composing my post.[/edit]
By the way, as a potential point of interest, even without any interactions (other than gravity), dark matter particle orbits will still decay over very long time scales. The argument goes as follows:
1. From time to time, dark matter particles will have close interactions with other dark matter particles that exchange energy between them. This means that the particles of dark matter in a potential well will be thermalized: their energy distribution will approach a thermal distribution with time.
2. A thermal distribution has a high-energy tail of particles that have enough velocity to escape the potential well. Thus the particles in the high-energy tail of the thermal distribution are always escaping. Since it is the highest-energy particles that escape, the average energy per particle is reduced in this process, meaning that it causes the cloud to collapse.
I do not know if this effect or the (weak) non-gravitational dark matter interactions turn out to be the dominant effect in controlling the long time scale behavior of dark matter.
Chronos said:
Those headlines seem to be a bit misleading. The only thing that was found, as near as I can tell from reading the articles, is that the density of dark matter in the vicinity of black holes is not large enough to produce runaway accretion of dark matter into the black hole.
These studies assert dark matter comprises a miniscule amount of the mass of black holes. Quoting from page 6 of arXiv:0802.2041v1:
" . . . We found that dark matter contributes to no more than 10% of the total mass accreted by black hole seeds."
This is the conservative upper limit and suggests black holes tend not to absorb dark matter, hence the headlines.
This is exactly what has been said in this thread: DM is less readily absorbed by black holes because it can't form accretion disks. It contradicts the claim that DM "would pass right through a black hole".
The dark matter component of black holes appears to be vanishingly small, or nonexistent. It may be that dark matter does not accrete and just slides by, or that it simply passes through black holes. The properties of dark matter are not understood, nor is it necessarily bound to our present understanding of the laws of physics.
It is bound to gravitate. That's how we know about it.
So no, it will not pass through a black hole. No way.
If DM particles passed through BHs, then I think that would prove that it is not a particle at all subject to following the curvature of spacetime.
...which would indicate that they couldn't cluster, which would be incompatible with our observations.
Guessing is not science. Compare hypothesis to hypothesis, hypothesis to observations. Logic analysis (pros/cons of each hypothesis) as opposed to picking a hypothesis and force feeding the observations to the chosen hypothesis.
It is a mistake to discard any reasonable hypothesis, however, if the "laws of physics" must be changed to make a hypothesis work that should be reason to consider other explanations.
AGN and QSO Super Massive "Black holes" have a maximum mass of approx. 3 x 10^9 solar masses. (That is one of the observations that requires an explanation.)
There is currently no explanation for the 3 x 10^9 solar mass BH limit observation. Galactic mergers in addition to dark matter would if "black holes" are classic black holes have created black holes in excess of 3 x 10^9 solar masses. (i.e. As noted because dark matter has not been detected and because there are observations such as the spiral galaxy rotation velocity variance with radius that is not in accordance with simulations that use the dark matter hypothesis, it possible that dark matter does not exist. Even if dark matter does not exist, normal matter would have created SMBHs in excess of 3 10^9 solar masses due to galaxy mergers based on statistical analysis of the number of mergers with time and the mass of SMBH merging.)
Here are other related observations that might help to provide a guide to the solution. (Think about Disney's finding that spiral galaxy parameters (luminosity, rotation velocity, and mass) are controlled (non-random) which indicates there is a single unknown parameter/mechanism that is controlling the spiral galaxy.
There is the problem of how to explain why spiral galaxies have not become elliptical galaxies due to mergers.
There is evidence of bimodal emission of spiral galaxies. The bimodal emission mechanism appears to be related what causes star burst galaxies.
We need a thread summarizing QSO observations.
The QSO spectrum is non-thermal generated. There are peculiar QSO emission structures (i.e. What moves matter in peculiar locations around the QSO and what causes it to emit in those locations?). QSO emission shows unexplained long term (periodic variation continues throughout the observation period, 30 years) periodic variance. 10% of QSO are naked quasars, which have the narrow region emission, but do not exhibit broad line region (BLR) emission (BLR is believed to due to emission from an accretion disk). The point is the QSOs in question do not have an accretion disk and are by some other mechanism causing the narrow line emission.
In the vicinity of our galaxy's SMBH there are peculiar paradox of youth stars. (Short lived very large stars located very close to galaxy's core.) These peculiar stars are OB very large stars which have peculiar orientations. (There are for example two strings of these supposedly OB stars in our galaxy that are orientated 90 degrees to each other with opposite rotations about the massive object at the center of our galaxy.)
There is the Holmberg effect. Satellite dwarf galaxies that orbit our galaxy and other spiral galaxies are aligned 90 degrees to the plane of the spiral galaxy.
There is the recent finding of Ultra Luminous x-ray sources in the vicinity of spiral galaxies's core.
Galactic clusters have anomalously hot intergalactic gas that is emitting x-rays. (10^7 K, very, very large structures). There is no explanation as to what could heat the cluster intergalactic gas to such high temperatures and there is no explanation as to why the cluster intergalactic gas has not cooled. The cluster intergalactic gas mass is roughly the same as the mass of the cluster's galaxies' mass.
http://arxiv.org/PS_cache/arxiv/pdf/1002/1002.0553v1.pdf
An upper limit to the central density of dark matter haloes from consistency with the presence of massive central black holes
We study the growth rates of massive black holes in the centres of galaxies from accretion of dark matter from their surrounding haloes. By considering only the accretion due to dark matter particles on orbits unbound to the central black hole, we obtain a firm lower limit to the resulting accretion rate. We find that a runaway accretion regime occurs on a timescale which depends on the three characteristic parameters of the problem: the initial mass of the black hole, and the volume density and velocity dispersion of the dark matter particles in its vicinity. An analytical treatment of the accretion rate yields results implying that for the largest black hole masses inferred from QSO studies (> 10^9 Solar Mass), the runaway regime would be reached on time scales which are shorter than the lifetimes of the haloes in question for central dark matter densities in excess of 250M_ pc−3. Since reaching runaway accretion would strongly distort the host dark matter halo, the inferences of QSO black holes in this mass range lead to an upper limit on the central dark matter densities of their host haloes of _0 < 250M_ pc−3. This limit scales inversely with the assumed central black hole mass. However, thinking of dark matter profiles as universal across galactic populations, as cosmological studies imply, we obtain a firm upper limit for the central density of dark matter in such structures.
http://arxiv.org/abs/astro-ph/0501312v1
Ultra-luminous X-ray Sources in nearby galaxies from ROSAT HRI observations II. statistical properties
The statistical properties of the ultra-luminous X-ray source (ULX) populations extracted from the ROSAT HRI survey of X-ray point sources in nearby galaxies in Paper I are studied to reveal connections between the ULX phenomenon and survey galaxy properties.
This survey confirms statistically that the ULX phenomenon is closely connected to star formation activities, since ULXs preferentially occur in late-type galaxies rather than in early-type galaxies, and ULXs in late-type galaxies tend to trace the spiral arms. Only 5% of the early-type galaxies host ULXs above 1039 erg/sec, with 0.02±0.10 ULX per survey galaxy and −0.13±0.09 ULXs per 1010L⊙ that are consistent with being zeros. In contrast, 45% of the late-type galaxies host at least one ULX, with 0.72± 0.11 ULXs per survey galaxy and 0.84 ±0.13 ULXs per 1010L⊙. 70% of the starburst galaxies host at least one ULX, with 0.98±0.20 ULXs per survey galaxy and 1.5±0.29 ULXs per 10^10L. An increasing trend of the occurrence frequencies and ULX rates is revealed for galaxies with increasing star formation rates. Two ULX populations, the HMXB-like ULXs as an extension of the ordinary HMXB population associated with the young stellar population and the LMXB-like ULXs as an extension of the ordinary LMXB population associated with the old stellar population, are both required to account for the total ULX population.
I don't see why this is special. Likely just a matter of friction and/or tidal forces coupling the angular momenta. Or coincidence, in some cases.
I don't see how this could possibly highlight the nature of dark matter, as it's most likely radiation from the accretion disk around the galaxies' central black holes.
This, as far as I know, isn't a problem at all. The gas is heated by falling into the cluster's gravitational potential well. As it cools, it collects into either the existing galaxies within the cluster, or creates a new one. New gas falling into the cluster keeps the cluster gas hot.
As I said, there is an increasing set of observations that support the assertion that what we call a SMBH is a physical astrophysical object that can generate magnetic fields and that evolves with time.
There is due to how scientific ideas develop, are taught, and how difficult it is to change ones mind when a strong position has been taken, theoretical inertia which makes it difficult to even consider other explanations.
http://arxiv.org/PS_cache/arxiv/pdf/0912/0912.2040v1.pdf
The Spectral Energy Distribution of Fermi bright blazars
The results of this study lead to the conclusion that a simple homogeneous, one-zone, SSC model cannot explain the SED of the majority of the detected sources, especially of the LBL type (see Fig. 36). In addition, differential variability in the simultaneous optical and Xray data observed in IBL and HBL objects (that is close to the peak of the synchrotron component) suggests that multiple components are present in non LBL blazars (e.g., S5 0716+714, Giommi et al. 2008) as also clearly shown by simultaneous X-ray/TeV campaigns (e.g., PKS 2155-304, Aharonian et al. 2009). Our results also show that ERC models can easily fit the data as they can cover a very wide part of the parameter space of Fig. 36 (orange squares). However, models that are based on the presence of external radiation fields that are significantly different in FSRQs and BL Lacs, such as the broad-line region, accretion disk etc., must explain why a) the ratio of the number of FSRQs and BL Lacs of the LBL type (which have similar -ray spectral slopes and therefore are affected in the same way by the higher LAT sensitivity to hard sources) is similar in radio/microwave selected samples (e.g., 1 Jy, WMAP) and in the LBAS -ray selected sample, and b) why BL Lacs appear to show equal, or even larger, values of SSC peak (that is larger -ray excess above SSC) than FSRQs in Fig. 36. Finally, any emission model should explain why only less than 13% of bright radio sources (F > 0.5 Jy @ 1.4 GHz) of the LBL type are in the LBAS sample, while the other 87% with similar observational properties are below the LBAS detection threshold and may well be radiating close to simple SSC. We intend to address these topics in future papers.
Observations point in a theoretical direction.
http://arxiv.org/abs/astro-ph/0406163v1
Naked active galactic nuclei
In this paper we report the discovery of a new class of active galactic nucleus in which although the nucleus is viewed directly, no broad emission lines are present. The results are based on a survey for AGN in which a sample of about 800 quasars and emission line galaxies were monitored yearly for 25 years. Among the emission line galaxies was the expected population of Seyfert 2 galaxies with only narrow forbidden lines in emission, and no broad lines. However, from the long term monitoring programme it was clear that some 10% of these were strongly variable with strong continuum emission. It is argued that these objects can only be Seyfert 1 galaxies in which the nucleus is viewed directly, but in which broad emission lines are completely absent. We compare these observations with other cases from the literature where the broad line region is reported to be weak or variable, and investigate the possibility that the absence of the broad line component is due to reddening. We conclude that this does not account for the observations, and that in these AGN the broad line region is absent. We also tentatively identify more luminous quasars from our sample where the broad emission lines also appear to be absent. The consequences of this for AGN models are discussed, and a case is made that we are seeing AGN in a transition stage between the fuel supply from a surrounding star cluster being cut off, and the nucleus becoming dormant.
http://arxiv.org/abs/astro-ph/0509433
Discovery of a bright quasar without a massive host galaxy
Quasars are thought to be powered by the infall of matter onto a supermassive black hole at the centre of massive galaxies1,2. As the optical luminosity of quasars exceeds that of their host galaxy, disentangling the two components can be difficult. This led in the 1990’s to the controversial claim of the discovery of 'naked' quasars3–7. Since then, the connection between quasars and galaxies has been well established8. Here we report on the observation of a quasar lying at the edge of a gas cloud, whose size is comparable to that of a small galaxy, but whose spectrum shows no evidence for stars. The gas cloud is excited by the quasar itself.
If a host galaxy is present, it is at least six times fainter than would normally be expected8,9 for such a bright quasar. The quasar is interacting dynamically with a neighbouring galaxy – which matter might be feeding the black hole.
Chalnoth said:
I don't see why this is special. Likely just a matter of friction and/or tidal forces coupling the angular momenta. Or coincidence, in some cases.I don't see how this could possibly highlight the nature of dark matter, as it's most likely radiation from the accretion disk around the galaxies' central black holes.This, as far as I know, isn't a problem at all. The gas is heated by falling into the cluster's gravitational potential well. As it cools, it collects into either the existing galaxies within the cluster, or creates a new one. New gas falling into the cluster keeps the cluster gas hot.
These anomalies each deserve their own thread to explain why they are anomalies. You have an immediate answer but you have not seen the observations and related analysis.
There is no logic reason why the first developed hypothesis is the correct hypothesis. It appears that it is very difficult for people to even think about competing hypotheses. It seems people cannot think hypothetically. After a period of time theories appear to become written in stone. People seem very convinced that the massive object is a classical BH and are viewing all the observations from that theoretical viewpoint. There seems to be a mental block to consider other hypotheses.
What is required for this thread is an explanation as to why SMBH have a mass limit which is one of the anomalies that requires explanation.
It suggested the answer to that question requires an answer to what is the massive object in the center of the galaxies and how it evolves. Matter goes into the SMBH. Can it come out?
Is there any observational evidence that supports the assertion that matter comes out of the SMBH? Evidence of periodic variation of emission from the massive object for instance. If there is, what force is causing ejection of the matter from the SMBH? The point is there must be a build up and release.
It seems there are observations that support the assertion that the SMBH is a physical object that evolves, not a classical BH that can only emit due to its accretion disk.
Rather than agreeing or disagreeing with that statement, I suggest that we can view the observations from the standpoint of the different hypotheses, a dynamic massive object and classical BH model and then look for observations to support or refute either hypothesis.
And this is different from a black hole how, exactly?
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 134 ·
11K
  • · Replies 16 ·
