Do gravitational waves have different frequencies?
14 replies · 3K views
Mu naught
I'm wondering if gravitational waves can have a wide range of frequencies and wavelengths much like EM waves, or if they are more uniform and only vary in amplitude.
Also, should gravitational waves experience a Doppler shift?
DaleSpam said:
They would vary depending on the orbital period of the source.
ah, but we can measure the orbital period of things quite accurately can we not? I ask because, if we can someday detect gravitational waves, it seems to me they should be a very accurate way to measure the distance to objects which we only have rough ideas about now.
DaleSpam said:
How so?
Because if we know the intrinsic frequency of the G waves a body is emitting by being able to visually measure it's period and determine it's mass, then by measuring Doppler shift we'll know exactly how far away it is. Unlike EM waves where we have no way of knowing what frequencies a body emits intrinsically.
The Doppler shift would be the same for the visual measurement and the gravitational measurement, so it would not provide any additional information. Also, we do know characteristic spectral frequencies that are emitted for EM waves, so we can already determine Doppler shifts.
It is true that gravitational waves from inspiral compact binaries would provide a standard candle for accurate distance measurements. I don't think this is quite true for general sources of gravitational waves.
Consider this: if the binary system recedes from us at velocity that gives it measurable z>0, then its successive observations would be shifted by the same amount as the EM Doppler shift. So we can't really measure its "true" frequency. We'll measure some number that will happen to be equal to the frequency of the G wave, rendering the mechanism useless for the purposes of measuring Doppler shifts. (Well, maybe those frequencies won't be 100% exactly equal, I think you'd need to do some GR calculations to confirm that ... but I'm pretty sure that first-order effects will cancel out.)
In this aspect, EM is much nicer, because there are specific patterns corresponding to spectrum lines of known elements. The problem is usually with determining the natural brightness of the object.
And, most important of all, we are nowhere near close to measuring G waves of objects at z>>0. For now, we're talking about launching some space probe by 2020 that _might_ be sensitive enough to detect G waves of binary star collisions and black hole mergers within our own galaxy. As of today, I'd say we're about 5 orders of magnitude short in terms of distance, therefore 10 orders of magnitude short in terms of sensitivity.
Completely false. LIGO could today detect black hole mergers of 10 solar mass black holes out to a distance of 3Mpc, and a merger of 50 solar mass black holes out to a distance of 120 Mpc. (Ref: http://arxiv.org/abs/0711.3041). So we can see well out of our galaxy.
nicksauce said:
Redshift 2 or 3 sounds a bit high to me... I wonder if, being from 1994, that paper is outdated.
It's possible but I don't have any more modern numbers. The noise curves for Advanced LIGO predicted in that paper are very similar to the ones predicted today by LIGO.
I stand corrected.
Yes, it seems that we can observe black hole mergers in our Local Group with LIGO already ... unfortunately, since LIGO has been running for close to 10 years and so far it has found squat, we can conclude that either G waves do not exist or black hole mergers are exceedingly rare.
What I should have said is that we're hoping to launch a probe that might be sensitive enough for gravitational waves originating from some of the "regular" orbiting binary systems in our galaxy.
hamster143 said:
I stand corrected.
The papers I've read predict an observable event rate anywhere between ~3 and 100 per year for inspiral compact binaries at the LIGO/VIRGO network. LIGO is still undergoing "science runs" and improving sensitivity. The new Advanced LIGO is due to start running at around 2015 and hopefully there will be some signals detected then.
hamster143 said:
I stand corrected.
The expected LIGO event rate is about 3 per century. No one is terribly surprised that we haven't found anything.
