Do Infinitely Many Prime Pairs Exist?
  • Level: Undergrad
  • Thread starter nnnnnnnn
    Prime
93 replies · 56K views · last reply
I see you are talking about 6x+1 and 6x-1;
I got some info about it,
First of all;
y=1,t=1
y and t increases y+1=2,t+1=2 and so on..
IF x = 5y-1 then
6x+1 is not a prime
IF x = 5y+1 then
6x-1 is not a prime
The above can be divided by 5!
The problem with the above formula is, new prime divisors comes to place to make the formula obselete. For example at 49 which is 7*7, 7 is added to the serie as a new divisor..And then you can notice that 11,13,17 starts joining the new divisors and this goes on as "x" increases...
Of course there might be a rule(if you ask me there is not) when these numbers become divisors of 6x + 1 or 6x - 1..If there is one good luck in finding it =)
of course there's a "rule" - the smallest (composite) integer of the form [itex]6n \pm 1 = m[/itex] such that [itex]p_i | m[/itex] where [itex]p_i \neq 2, 3[/itex] is prime is just [itex]5p_i[/itex]. For example, 7 is not "added to the series" at 49, this occurs at 35 = 7(5) [itex]\equiv[/itex] -1 (mod 6).
IF x = 5y+1 then
6x-1 is not a prime
Sorry but 35 can't pass my first logical test as,
When y=1
x = 6
5y+1 = 5+1 = 6
6x-1 is not prime
6*6-1 = 35 is not a prime
While the number didn't pass my test, No, 7 becomes the divisor for the first time when 6*8 + 1 = 49
And all of the prime numbers becomes the MAIN divisor for the first time when 6x+1 is the square of that prime number..
That is my observation at least...
I'm sorry... I don't understand your posts very well at all. I understand your tests for divisibility by 5 of numbers of the form [itex]6n \pm 1[/itex] - those are fine. I was responding precisely to this:
For example, 7 is not "added to the series" at 49, this occurs at 35 = 7(5) -1 (mod 6).
Then can you open this one a bit.
What exactly is a "main divisor"?
I also have no idea what you are talking about in the rest of your posts. 5 is a divisor of 6(1)-1, so why isn't 5 "added to the list" at this point? Could you perhaps elaborate on what you are trying to say?
Shmoe you should read my other prime post :wink:
To see why 7*5 is not added
MAIN divisor means its lowest divisor for example
77 : 11 is divisor, 7 is divisor but 7 is the MAIN divisor because it is the lowest possible number that can divide 77...
or
287 : 41 is divisor but as you can see above 7 is the MAIN divisor again..
You mean lowest divisor besides 1? You know this isn't a standard term. If you want to use your own terminology and expect people to understand you it's a good idea to provide your definitions.
So it seems that 7 is the main divisor of 7, why wouldn't you add 7 to your list at 7 then? (I had meant 7, not 5 in my last post, whoops) Or does "main divisor" mean "smallest divisor of a number other than itself or one"?
Do you mean this one https://www.physicsforums.com/showthread.php?t=38437 ?
Shmoe i understand why you don't understand..And that is because you are not thinking in the ways of an algorithm.
As you can see your observations has no computational use..And you still show me states which my algorithms first few lines has already eliminated. if you still don't know what i am talking about here it is again then;
y=1
y increases y+1=2 and so on..
IF x = 5y-1 then
6x+1 is not a prime
IF x = 5y+1 then
6x-1 is not a prime
As you can see above, The number 35 was eliminated by the algorithm already..So it primality is out of question already,
Number "1" divides all, so it is absurd to take it into consideration..
And why i don't take 7 at 7 is because it is a prime number, i am talking about non-primes that breaks the 6x+1, 6x-1 rule. Before making comments you should first look what I am talking about...
How about you actually write out your algorithm clearly then if you expect people to understand it.
It looks like you are hoping to cross of composite numbers n by checking for prime divisors that are less than sqrt(n) (this is a generous interpretation). If this is the case, why on Earth don't you just say this is the sieve of Erathosthenes (after "pre-sieving" 2 and 3)rather than make up your own terms and presenting things in such an incomplete and obscure way as you have here.
10 y=1, x=1
20 If 5y-1<x Go to 60
30 If 5y+1<x Go to 70
40 If 5y-1=x Go to 90
50 If 5y+1=x Go to 100
60 Print "6x+1" is a possible prime
70 Print "6x-1" is a possible prime
80 x=x+1 Go to 20
90 Print "6x+1" is not a prime it is divisible by 5. Go to 50
100 Print "6x-1" is not a prime it is divisible by 5
110 y=y+1 Go to 80
I am waiting for your comments on the algorithm Shmoe, Thanks...
It has several problems, but from the looks of it you are just trying to remove multiples of 5 from the sequences 6n+/-1? You've included nothing about adding numbers to the list of divisors, which is where most of the confusion was.
If all you want to do is knock of multiples of 5 from the sequences 6n+/-1 there is a much simpler way to do it. Just use a divisibility test. If 6n+/-1 is divisible by 5, chuck it, otherwise move on.
Alternatively, if you've already generated the sequences 6n+/-1, and they're in order, say like 5,7,11,13,17,19,23,25,29,31,35,37,41,43,47,49,53,55..., you can remove 25, go 3 down the list, remove 35, go 7 down the list, remove 55, go 3 down the list, etc. Keep alternating between removing the 3rd and the 7th on the list and this will strike off every multiple of 5 (this pattern follows from where multiples of 5 that aren't divisible by 2 or 3 live mod 30).
Or you could instead consider all numbers of the form 30n+/-1, 30n+/-7, 30n+/-11, and 30n+/-13. All primes greater than 5 will be of this form (of course not every number of this form is prime) and none of the numbers of this list will be divisible by 5 (or 3 or 2). (this isn't really much different from the last paragraph though)
well shmoe if i had found a rule when the prime divisors join, i would have alrady created a perfect formula that always generates a prime number.
I guess I'm totally confused as to what you are trying to accomplish. As it stands your algorithm appears to be an attempt to find the numbers of the form 6n+/-1 that are not divisible by 5 (in other words numbers not divisible by 2, 3, or 5). Is this not a correct assessment?
Or are you considering this some kind of incomplete algorithm for finding all primes (up to a certain finite point I'd assume)? If so have you investigated and understood the simple sieve of Erathosthenes? Do you understand how it determines the next number to sieve by once it hits the end of the list?
Hurkyl said:
I love this theorem: the Frivolous theorem of Arithmetic.
How true that theorem is. :smile:
I was thinking about some stuff and had some questions and thoughts.
1 - The distance between prime numbers seem to be mostly prime numbers themselves (although not always). Does this pattern hold that most are that way? Or maybe the higher the prime number goes, the more likely you'll have a non-prime number between them. Does anyone have a big list of primes with facts about things like this?
2 - Testing numbers by dividing them by primes. I'm sure there are better ways to check for prime numbers than just checking every single number. I figure numbers could move from one group to another to verify further and further whether they're prime or not. Any thoughts?
3 - Why are there prime pairs? What other interesting characteristics are there about primes? What do you mean by divisible by one and itself? Really what does that mean (deeper).
Is infinity a prime number? I know that sounds silly since infinity isn't really a number, and it's not really divisible by itself the same way that "regular" numbers are; but maybe prime numbers can be termed as some abstract quantity just as infinity is. I'm guessing this is pretty dumb; but just throwing thoughts out.
4 - The largest prime is (infinity/2) -1? Again... infinity... oh well. I'm not sure you could prove that there is a limit to prime numbers since you have that big old infinity there; but would there be a point where prime numbers would be in greater abundance as they get bigger? Like a wave function Cos(x). So at first you have a lot of primes... then the number drops rapidly... but could it go back up? Why or why not?
Please ignore my questions if they are too dumb.
1. This is false, the distance between any two odd numbers is even, and the only even prime is two. Essentially the distance between two primes is primes when you have a pair of twin primes. (note this covers the distance between an odd prime and 2 being prime as well).
2. For a start, you only need to check for divisors less than a numbers square root. There's the Sieve of Erathosthenes, one of the simplest yet still effective ways to produce a list of primes. There are much better primality tests than thie naive divisibility test though, Elliptic Curve methods, AKS algorithm, and many many more, including specialized tests for numbers of a certain form (such as Mersenne primes).
3. Shucks, that's a tough one. In some sense the primes a pretty random, so it's not suprising if they sometimes get close to one another. No one knows yet if there are infinitely many of them, so it's not really possible to give a reason why they are there.
Being prime means you cannot be factored in anything but the most trivial way. You can think of primes as the building blocks of all natural numbers. Remember the Fundamental Theorem of Arithmetic?
Infinity is not a natural number, therefore it doesn't stand a chance at being called prime. First thing you have to do to be considered into the club of primeness is become a bonafide natural number, which infinity is really bad at doing.
4. There is no largest prime, there are infinitely many (you should be able to find the usual proof attributed to Euclid without much difficulty). The do become scarcer as you go out. If you were to grab some random number near a large number x, the probability that it's prime is about 1/log(x) (that's the natural logarithm). The prime number theorem says that is the number of primes less than or equal to x is about x/log(x).
However this isn't to say that there aren't quite a few of the little guys running around. You know [itex]\sum_{n=1}^{\infty}1/n[/itex] diverges but [itex]\sum_{n=1}^{\infty}1/n^2[/itex] converges, so in some sense there are far fewer perfect squares than there are natural numbers. Now [itex]\sum_{p\ prime}1/p=1/2+1/3+1/5+1/7+1/11+\ldots[/itex] diverges (the sum is over all primes), so there are still a considerable number in some sense.
Oops! You're right... What I meant was the amount of numbers between them. i.e. between 7 and 11 there are three numbers (8, 9 and 10). Sorry about that.
Wow! I had no idea. Could you use all of these tests? For example, use one test and all numbers that pass use the second test on them and so forth and see if there is a pattern or a quicker way to find primes? I'll have to look at some of those. Any discussions on PF for those?
So this is more coincidental and can't really be reasoned mathematically?
Primes are the building blocks in that they are more fundamental since they are only divisible by one and that number? What's the next step up? Having numbers divisible by 1, 2 and that number? What would those be called? Next divisible by 1, 2, 3 and that number? I guess in that sense there should be numbers that are more rare than prime numbers that would be more fundamental than prime numbers then. What would those be? What about numbers divided by fractions? I'm just rambling here, sorry. :biggrin:
LOL... yeah... sounds like infinity won't fit the picture very well. So in that sense you can't have an infinite amount of prime numbers since infinite is not a concept that would match a prime number sequence?
shmoe said:
4. There is no largest prime...
I was just joking about that. :wink:
shmoe said:
...there are infinitely many (you should be able to find the usual proof attributed to Euclid without much difficulty). The do become scarcer as you go out. If you were to grab some random number near a large number x, the probability that it's prime is about 1/log(x) (that's the natural logarithm). The prime number theorem says that is the number of primes less than or equal to x is about x/log(x).
Ok, that makes sense, even to someone as limited as I am in my knowledge of math and science.
Sum over all primes diverges... that sounds odd to me... would that mean that there are NOT an infinite amount of primes?
1. Ahh, I see. This could be a function of looking at only small numbers where the distances between two primes is even smaller, and an unnaturally large percentage of "small" odd numbers are prime. Up to the first 100 or so primes the largest gap is 17 numbers long. If all these gaps were somehow randomly chosen odd numbers from 1 to 17, you'd expect about 6/9 of them to be prime, which turns out to be close to the truth.
2. If a test declares a number prime, why would you want to apply another primality test to it? There are some "probabilistic" primality tests where you do repeated applications, but I don't think that's what you meant. Google "primality testing", you'll probably find heaps of info.
3. It's probably not coincidental. There are convincing heuristic arguments (read-arguments with gaps in them) that would indicate there are infinitely many prime pairs. It is also known that there are infinitely many pairs p, p+2 where one is prime and the other has at most 2 prime factors, that's coming tantalizingly close to a solution (yet so far out reach still).
Next best thing to primes would be a low number of prime factors. In some ways they can be hard to separate (see paragraph above). Prime powers are also pretty decent too.
not sure what you mean about "infinite is not a concept that would match a prime number sequence", since you seem to agree there is no largest prime and therefore infinitely many of them.
4. Quite the opposite about the sum of recipricals of the primes diverging, showing this sum diverges is one way to prove there are infinitely many of them. If there were a finite amount, then this sum would have a finite value. However by adding up enough terms, you can make this sum as large as you like. It turns out if you add up 1/p for all primes less than say x, you'll get about log(log(x)), which although going to infinity very slowly, it still goes.
I ran my program from about 1,000,973 to 1,002,361 and came up with these results:
7, 17, 3, 13, 5, 3, 13, 27, 11, 5, 1, 3, 13, 15, 29, 5, 13, 3, 13, 5, 21, 17, 29, 11, 11, 11, 7, 9, 1, 3, 19, 5, 15, 11, 5, 1, 11, 9, 19, 15, 11, 7, 23, 9, 25, 3, 17, 1, 11, 5, 17, 5, 27, 7, 9, 19, 9, 13, 3, 25, 9, 19, 39, 13, 3, 5, 1, 11, 9, 7, 71, 21, 7, 5, 5, 23, 3, 1, 5, 27, 31, 11, 11, 3, 5, 7, 9, 7, 11, 21, 5, 1, 21, 17, 35, 13, 5, 9, 1, 3, 25, 9, 41, 1, 3, 1, 9, 1, 15
The ratio here is presicely 27/109 (or about 1/4). Less than 2/3; but fairly close. Interesting that the ones that most come up which are not prime numbers are divisible by prime numbers... some big endless loop I'm sure, since you take those (ie. 9, 15, 21, 27) and we find that they are divisible by three and some other prime number... and it continues... I don't dare push my program too far. It already takes almost 0.10 seconds to calculate terms over 5,000,000. I did it in C++ if anyone wants the code (it's pretty small).
EDIT: Another quick note. The amount of numbers listed here always seems to be divisible by a prime number. Do they take that into account when they attempt to find a prime?
ADDITIONAL EDIT: They are divisible by any prime that I can calculate, except for the number 2 (of course), so I would submit that 2 is not in the same category... not that it couldn't still be a prime; but it's not the same type.
I did mean "probabilistic" there. You're right, it wouldn't make much sense using another prime number test on a prime number. :biggrin:
Wow! Sounds like they're on the right track. I'm not great with number crunching. I just do the thinking. :smile:
Interesting. I wouldn't have thought of prime powers.
I'm not sure either... I guess what I was getting at was that since infinity isn't really a defined quantity; but a concept, or limit, or... help me out here... anyway... since it's not a "natural number" (I think that's what you've called it), then saying that numbers (which happen to be "natural numbers") have an infinite limit (limit that is not "natural") seems to conflict. Though I'm sure it doesn't but it sounds like it. :rolleyes:
Interesting as well... I must have missed something in my math classes. I, for some reason, am not aware of the relationship between primes and log(x); but many people seem to have mentioned it. What is that relationship exactly?
1. If a number isn't prime then it's divisible by a prime. Notice how small the gaps are (in your range 39 or less). The prime number theorem will tell us that the average gap sioze for primes less than x will be about log(x) (as there are x/log(x) primes). So if your looking at a bunch of "randomish" odd numbers that aren't much larger than log(x), you'd expect "many" primes. Furthurmore, the ones that aren't prime will have a prime factor no greater than their square root, so it's no surprise you see 3 often there. The only composite number less than 39 without 3 as a factor is 25 (which did occur in your range)
3. There's no problem with saying there are infinitely many primes. You accept that there are infinitely many integers? It's just a statement about cardinality of sets.
4. See the prime number theorem. The log there is really the cause of so many other logs. I'll have to think about a simple way of explaining why it makes an appearance there.
non-primes in prime positions, non-primes in non-prime positions
My work in prime numbers has delivered me evidence that prime numbers are not connected to each other due to their prime nature, but due to the connections of the other numbers in prime number locations (which happen to be multiplications of prime numbers). I wrote extensively about this in Chapter 5 of In Search of a Cyclops http://www.pentapublishing.com/CyclopsBook5.html . Published as The Proof of Nothing in the year 2000.
When dividing all numbers in series of six it is possible to see that there are prime number positions and non-prime number positions. All prime numbers (except 2 and 3) appear in either the first position or in the fifth position. See http://www.pentapublishing.com/images/table1.gif
I made the choice to place 1 with the prime numbers even though that is not considered correct. The link between prime numbers is not a link between the prime numbers, but a link between the non-prime numbers. See http://www.pentapublishing.com/images/table2.gif
What are the red numbers in this table are non-prime numbers in first and fifth positions. These red numbers follow a pattern, like for instance those divisible by 7. See http://www.pentapublishing.com/images/table4.gif
As you can see in this table 7 'cuts' out numbers in turns in first and fifth positions according to a pattern of 4 plus 3 lines of six down.
All prime numbers 5 and up 'cut' away first and fifth position numbers from the prime number list according to a very strict and specific regimen. See http://www.pentapublishing.com/images/jump.gif which shows two numbers after each prime number (or multiplication of a prime number), portraying the lines of six jumped to take out numbers off the prime number list. All prime number multiplications follow these kinds of number specific jumps - and all these jumps are linked together. Therefore all prime numbers can then be calculated according to a subtraction method. It is not the link between them, but the link that eliminates the others from being prime numbers. From this information a new method can be created to quickly appoint the prime numbers for which I am in the (long) process of getting a patent (question so far is if that will happen).
Once you understand how non-prime numbers are formed, it becomes obvious (and a little bit boring) to see which numbers remain as the prime numbers. All prime numbers would appear in two packs if it wasn't for the multiplications of prime numbers taking numbers off that list of prime numbers. Have a look at http://www.pentapublishing.com/CyclopsBook5.html , a Chapter I wrote to deliver evidence that zero is intrinsic to the natural numbers (not a natural number itself according to number theorists - but which is a natural number according to set theorists).
I don't understand what you think is new or worthy of a patent. If you've read this thread (or really any number theory text) you'd know that considering primes mod 6 is nothing new. Knocking off non-primes by considering all the numbers mod 1 or 5 mod 6 then removing multiples of 5, 7, etc. is just a slightly modified sieve of erathosthenes. This pattern of "jumps" in lines when you're removing multiples of a prime p is not difficult to explain, you're just adding this prime again until you hit 1 or 5 mod. If p=6k+1 then your "link pattern" is 4k, p-4k. If p=6k+5 it's 2k+1, p-2k-1 (both these are easy to prove).
That your "jump.gif" chart has a pattern that can apparently go backwards nicely is only because your table is too short. The 'etcetera" at the bottom is misleading as this pattern does not continue if you're putting primes in the left column, it's only there because there are no composites congruent to 1 or 5 mod 6 less than 24. Though it does occur to me that you might want to include 25 on this table as well (and all numbers congruent to 1 or 5 mod 6), in which case this 'link-pattern' is just a trivial observation (simple to prove with modular arithmetic) that says nothing about primes.
Including 0 as a natural number or not is totally irrelevant to how any number theorist will think. It's just a convention that's been adopted over the years as being the most convenient (or at least not terribly inconvenient). Number theorists are not at all restricted to working with the natural numbers and will jump around to integers, algebraic number fields, complex numbers, and more exotic systems, and I assure you never forget about the existence of 0.
The same goes for putting 1 in it's own special category. The fact that it has a multiplicative inverse in the integers makes it fundamentally different from everything else. For this reason it behaves sufficiently different from 2, 3, 5, 7, ... etc. that it doesn't share most of their interesting properties. Of course you could include 1 as a prime if you really wanted to set your definitions up that way, but you'd find many theorems beginning "let p be a prime other than 1". It's just a definition made to simplify discussions that's generally been agreed upon.
It seems through the test that I've run, that:
All prime numbers have [tex]n[/tex] numbers between them.
Where [tex]n[/tex] is the product of two prime numbers.
This works with all prime numbers except for "2". 2 is never used to find [tex]n[/tex] and between 2 and 3 there are 0 numbers, and no two primes multiplied together make 0. Any thoughts on that?
Could there be a function to find all prime numbers where [tex]n[/tex] is 3? Or a function where [tex]n[/tex] is 5, or 7, or any other prime number? Where the function would pass through each of the prime numbers (either the first in the pair of the sequence or the last in that pair).
If you go out far enough, you'll see this is false, the next prime after 1098847 is 1098847+106, there are 3*5*7 numbers between them. I mentioned the conjecture that there are infinitely many twin primes, Hardy and Littlewood gave a more refined conjecture that gives an asymptiotic for how many their are (like the prime number theorem). It goes beyond this to predict asymptotically how often any size gap will appear (recall twin primes correspond to a gap of 1). Long story short, all possible gaps are expected to appear infinitely many times (though not all at the same frequency).
Sure, there can be a function that does this, but it's almost surely not what you are hoping for. Let f(k)=kth prime p that is followed by n composites then a prime. Not at all computationally useful, but it's cetainly a function. Probably for any simple restrictions on what you're hoping this function to satisfy, it will either be impossible or at least not possible by todays technology.
Of course between any pair of twin primes there is 1 number and 1 is not the product of two primes.
Good point- for some reason I assumed he meant at most two primes.
Oh, you're correct. I was considering "1" as a prime and "2" as a non-prime. Although it's not really the "Prime" number system if done that way. So it's a different number system I guess that has the same numbers except for 1 is included, and 2 is excluded. Other than that it works. :biggrin:
Yeah... I guess the only way to get a true function for the infinite series is to know all values of the series (or what they will be), so the function given won't help out. We need a function that would give answers by plug and play.
There's got to be another pattern... come on, you guys are math wizards... think, THINK! :smile:
Do you think it can actually be solved? Or do you think there really is no pattern so it can't really be solved?
So how about this:
Where [tex]n[/tex] is a product of primes.
Does that work? (again with the exception of "2").
Rahmuss said:
So how about this:
This is trivially true (barring the "1" exception, unless you conisder an 'empty product' a product). Remember the Fundamental Theorem of Arithmetic?
shmoe said:
...Remember the Fundamental Theorem of Arithmetic?
Not sure what that is... let me look it up... Oh, I see. So no big deal that they can be expressed in prime numbers; but most of the time they are a single prime (as you stated above) and the number 2 is never used, so there is a slight difference.
Funny that the theorem was stated by "Hardy and Wright" and my last name is Wright and my cousins last name is Harding (close enought). :biggrin:
I still think there is a clue in what the [tex]n[/tex] is that will give useful information.
So will it be solved then? So far, all we have are ideas which give only few prime numbers, or ideas which give probable prime numbers. No plug and play yet.
