ChrisPeace said:
Is everything in the universe simply falling at a terminal velocity with no bottom?
Where would they fall? There's no up or down in space, nor is there any universal gravity field.
ChrisPeace said:
Are we really AFLOAT on the fabric of space, because it would seem to me that if objects of significant mass can warp space, then they must have the weight to make it bend.
The "rubber-sheet" analogy is just that, an analogy. In the analogy, a curved 2D sheet stands for curved 4D spacetime (and you should really picture objects as being completely contained in the 2D surface rather than sitting on top of it, as in the story
Flatland). Also, it isn't important to the analogy that masses cause depressions in the sheet, you could equally well picture them causing raised bumps in it--all that's relevant is that it changes the curvature of the sheet, the orientation of the curved surface is irrelevant. Are you familiar with the notion of "geodesics" on a curved surface? On a curved 2D surface, they basically just mean the shortest path between two points--for example, on a globe, if you draw two points on the globe the shortest path between them will always be a section of a
great circle (like the equator or a line of longitude) that passes through both points, which might not
look like a straight line if you plotted the path on a map of the globe (it would depend what map projection scheme you used). In curved 4D spacetime, instead of minimizing the spatial distance, a geodesic is a path through space and time that
maximizes the "proper time" (time as measured by a clock moving along that path), and the geodesics will look different depending on the curvature just as they do on a curved 2D surface.
You might also find this helpful:
http://www.bun.kyoto-u.ac.jp/~suchii/apple.html
