Do Prime Numbers Follow a Pattern?
23 replies · 9K views · last reply
Raschedian
Hello everyone!
I was going through a simple high school level mathematics book and got to the following question:
n2 - n + 41 is a prime for all positive integers n.
You're supposed to find a counter-example and prove the statement false.
You could of course sit and enter different values for n until you get a composite number and then use that value of n as the counter-example.
But is there a way to find some pattern or rule for prime or composite numbers so that you don't have to do the work manually? This is probably a trivial question but I got curious. Thank you!
Mathematics news on Phys.org
There is no known pattern or rule for calculating prime numbers, but with a little thought you should be able to easily find a counter-example without laboriously going through numbers.
Thank you!
It's pretty easy to find a counterexample for the formula above, if you think about it. A similar formula is the following: n2 + n + 41. This one also appears to generate prime numbers. It's a little harder than the first formula to spot why not all of its values are primes.
Uh? Simple proof? Hmm... how come... hmmm... hmmmmm...
Ah! It's the same reason why ##n^2-n+11## also doesn't generate prime numbers! Haha, smart problem!
Try writing it as n(n-1) + 41. Is there a vale of n that makes it obvious this is not prime?
I have once checked one of the polynomials up to ##n=100## and there are indeed disproportionately many primes as results. Does anyone know why? I mean in terms of Legendre symbols or so?
The way I thought of this was rewriting as ##n^2 + (41-n)##
That's what I thought also, but @phyzguy's approach allowed me to see the solution to
Hmm... I'm kinda missing the ##n*(n-1)+41##... how does that make it non-prime... hmm... 21*20?... 11*10?...hmm... can't be that... 41*40?... oh.. .41*40+41! hahaha... I got it! :biggrin: ... I'm so slow
It's actually the same thing as ##n*(n+1)+41##, I guess!
Well, maybe.
As a hint, consider that ##n^2 + n + 41 = n^2 + n + 40 + 1##, where the latter expression can be written as a perfect square trinomial for some value of n.
Mark44 said:
Yes, a commentary which reminds me not to write what I think.
AdamF said:
10.
(Didn't read the other comments.)
Maybe someone should tell him that ##10^2\pm 10+41## are both prime.
I read it as "n^2 - n - 41".
-- The way it's written is more immediate, though.
Reduce the last two terms to zero by setting n equal to the quantity you're subtracting.
In this case, take:
N = 41
It seems worthwhile checking to see, for a more general expression if you can find a way , a value , to make the expression be even or end in 5, as the simplest cases. Here , if n is odd, the sum is odd, same for ifn is even. Five will not work. Just mentioning as a general technique. Usually going by using the remainder of a well-chosen number should help.
Mathworld:
http://mathworld.wolfram.com/LuckyNumberofEuler.html
has an explanation in terms of Heegner numbers, but I'm not nearly smart enough to understand it :smile:
Nor me!
##\rm The~core~equation~for~~~##x2+x+41
##\rm~~~~~~~~~~~~~~~is~~~~~~~~~~~~~~~~##x2+163
this will be divisible by 163 at n=81
of course, at n=40 , i.e. 40 x 41 [x1]
##~~~~~~~~~~~~## and n=41##~~~~~~~## 41 x 42 ##~~ "##
the first composites ( of 41) are produced at and then below the square root of the function ( of x)
Janosh89 said:
Nor me!
What is a "core equation" and why is ##x^2 + 163## a core equation for ##x^2 + x + 41##? Also note that neither ##x^2 + x + 41## nor ##x^2 + 163## is an equation.
What will be divisible by 163? Without some elaboration, it would be difficult to see that ##81^2 + 163 = 81^2 + 2(81) + 1 = (81 + 1)^2##, but what does this have to do with ##x^2 + x + 41##?
The square root of what?
Please try to be clearer in your replies.
I will post, y=x2+163 in future
##81^2+81+41=163×41##
##y=x^2+x+41##
##∴y=163×41~ when~x=81##
alan2, back in post 17 gave the obvious answer: "let x= 41"! If x= 41, [tex]x^2+ x+ 41= (41)^2+ 41+ 41= 41(4`1+ 41+ 41)= 41(123)[/tex].
