force5
- 146
- 0
Do stable particles exist in any of the accepted theories such as string, Qm, GR or any others?
selfAdjoint said:So physicists put [tex]10^{30}[/tex] protons (the hydrogen nuclei in water molecules) in a tank deep underground (to escape disturbing cosmic rays) and watched them with skillions of electric eyes for a year. If the lifetime of the particle was [tex]10^{30}[/tex] years, then one in every [tex]10^{30}[/tex] protons should decay in a year. The experiment actually went on for several years and they never saw a proton decay. So the theory of Technicolor, however nice, had to be abandoned. Some of the supersymmetry theories also predict proton decay, but over a longer span of time.
Rybo said:Force 5 and Prometheus,
The way I udnerstand it there is 5 bosonic forces. Please correct me if this line o fthought is off base.
force5 said:If you have determined that EMR is the fundamental force, do you require any other substance to exist other than EMR?
What is the main focus of your research?
I've spent a lot of years determining possible angles, momentum, direction, volume and densities relative to propagation function.
connect said:I think that space and time are the infinites (making space-time or reality (a relationship)). In physics light is always defined by 2 parameters:
- the amount of distance from its start point to its end point
- the amount of time from the start time to the end time.
Another way of looking at that is that there actually 4 parameters:
- the distance start point
- the distance end point
- the time start point
- the time end point
You will notice that both the start points will usually start a zero, this is the point (another point?) we start measuring from.
You could then say there are 6 parameters, the above combined.
There are many relationships between numbers, but numbers simply represent a circular binary framework over time, i.e. 'one after another' (odd/even), it could be thought of as 'one flows into the other'.
force5 said:I know this doesn't answer all of your questions and is just the tip of the iceberg, but it's the best I can do at the moment.
