Do stars actually collide in galactic collisions?
  • Level: High School
  • Thread starter bostonnew
    Collisions Stars
16 replies · 9K views · last reply
bostonnew
Will some of the stars of the Milky Way crash into those of Andromeda if these galaxies merge?
What are the odds? How large a share of the stars will this happen to?
Thanks
Thanks
Writing in the book, "The Chilling Stars", science writer and Cambridge educated physicist Nigel Calder says of galactic collisions,
"Even with so many billions of stars involved, in each of the participating galaxies, the spaces between stars are so wide that the chances of a direct collision of two stars are slim. Instead, the high-speed encounter of gas carried by the galaxies creates shock waves that compress the gas and provoke its collapse into new born stars..."
Perhaps the Andromeda Galaxy will collide and merge with the Milky Way in 5 billion years, producing colossal starburst events.
Respectfully submitted,
Steve
To add slightly to Dotini's excellent answer, I read some where that although the odds of stars actually colliding is essentially zero, the odds of some solar systems being perturbed by near misses is slightly higher (STILL, as I recall, quite small)
For some perspective, we can scale stars down to about the size of a BB (or a pea). Assuming sun sized stars, and 4 mm sized BBs, the scale is about 347,750,000,000:1. If we assume 5 LY between stars the distance between our BB sized stars is about 136 km (85 miles). So imagine a cloud of BBs each about a hundred km away from the next nearest one. If two of those clouds 'collided' it would be pretty unlikely for any two BBs to collide. Of course, there are billions of stars/BBs and in the core the density goes up a lot. There will be some collisions, but for any individual star (like the sun) a collision is very unlikely.
Ok, thanks.
What if we leave aside galactic mergers for the moment. Do stars ever collide within galaxies as part of the normal way galaxies evolve? Under what kind of circumstances can this happen?
cmb said:
Now substitute 'stars' with 'nucleii' and 'galaxies' with 'fusion plasmas', and all of a sudden we have an argument that nuclear fusion is too slim a probability to happen!
It would seem inevitable that stars will collide... and at unimaginable speeds when two galaxies collide!
It's all a matter of scale.
"The core of the Sun is considered to extend from the center to about 20–25% of the solar radius. It has a density of up to 150 g/cm3"
http://en.wikipedia.org/wiki/Sunradius = 6.96E+010 cm
core radius = 1.39E+010 cm
core volume = 1.13E+031 cm3
density = 100 g/cm3
mass = 1.13E+033 g
percent H = 50.00%
moles H = 5.65E+032 mol
avogadro's number = 6.02E+023
H atoms = 3.40E+056
Stars in both galaxies = 1.00E+012
ratio atoms in sun's core to stars in galaxies = 3.40E+044
Obviously there's a lot of estimating there. But, even if they are all off by an order of magnitude there is still many times more atoms in a star than stars in a galaxy.
A head on collision would probably produce a few stellar collisions, but, andromeda will probably only rub halos with the milky way. It should still produce an amazing star burst event.
It depends on your definition of "collide". There is often mass transfer between stars in binary systems. This is a process that takes thousands or millions of years. The end result of this may be a single star.
There exists a category of stars called "blue stragglers", which appear to be formed by this process. They exist only in dense star regions in clusters, which suggests interactions between stars are responsible. There was a debate about whether these were formed by "mass transfer" or by "collisions", but it's now generally recognized that these are statements about the speed of the process, not the nature. If the two stars orbit a million times before merging, it's called "mass transfer". If they orbit ten times, it's a "collision". But it's the same process; the only open issue is how long it takes.
What evidence he have indicates that blue stragglers form under a variety of time scales.
density = 100 g/cm3
mass = 1.13E+033 g
percent H = 50.00%
H atoms = 3.40E+056
Good calculation.
Stars are governed by gravitational attraction. For any two stars to collide they would have to have a velocity vector directed towards each others centre of mass. Any sideways motion and the 2 stars would swing around each other. Perturbations from another third or more celestial bodie(s) could change the trajectory to a hit or a miss. Chances are that it would be a miss.
For the core of a sun, the particles are ionized, so a given particule would be subject to attraction and repulsion from other particules. That would change the dynamics to what -more favourable or less favourable for a collision?
Stars called blue stragglers that are much younger than the rest of the stars composing the Messier 30 globular cluster are considered remnants of stellar collisions.
Dont neutron stars sometimes collide releasing massive amounts of energy?
Galactic collisions aren't necessary for two stars to collide. Just as there is the danger of a rogue black hole appearing out of nowhere so too a rogue star might appear out of nowhere and collide with another. In places where distances between stars are closer, such as in the center of globular clusters or galactic hubs, such collisions are more likely.
These super dense regions also produce the supervelocity rogue stars that are gravitationally hurled out into interstellar or intergalactic space when the gravitational relationship between binaries changes when one of the two goes supernova or gets too close to a black hole and is partially disrupted or gets pulled in.
The trajectory of the remaining star when its gravitatinl tether "breaks" is unpredictable just as a rogue black hole's trajectory is. Very unlikely? Sure. Utterly impossible? By no means.
Almost certainly. There are many binary systems composed of double neutron stars that will eventually spiral into each other.
Would the velocity vector of star A necessarily be pointed at center mass of star B (and vice versa) for them to collide? depending on the relative speed of galactic collision, might it not be possible that many stars enter degrading binary orbits such that they produce collisions. not necessarily head on collisions, but more of a spiral into each other collision.
Also, depending on the local stellar distribution density, it may not be the case that there are numerous collisions but rather stars are stripped of their satellites by the pertubations of passing stars.
It's possible, but usually the case is that the stars are "flung" away from each other instead of becoming a binary system. I believe the two stars would have to have comparable velocities in the same general direction and be slowly moving together for them to enter a stable binary orbit. Not 100% sure on that though, I've never done the math and all.
Thanks
I cannot, unfortunately, back this with any reference or hard evidence, but I remember reading somewhere that if two galaxies with a billion stars each collide, the number of stars that actually hit each other would be literally a handfull. That is, something like 5 collisions or so.
well if you consider the typical size of a star, compare it to the typical distance between stars in a galaxy, then figure out the average density of stars in the galaxy, would that tell you how likely it would be for stars to collide during a "galaxy interaction event"?
