Does a Falling Tree Make a Sound if Unheard?
The discussion revolves around the philosophical and scientific question of whether a tree falling in a forest makes a sound if there is no one present to hear it. Participants explore definitions of sound, the role of perception, and the implications of observation in relation to physical phenomena.
  • Some participants argue that sound exists as a wave vibration regardless of whether it is perceived, suggesting that the physical phenomenon of sound waves is independent of observation.
  • Others contend that sound requires a receiver to be defined as such, asserting that without an observer, it is merely compression waves.
  • A participant proposes that the question could be reframed to explore the implications of unobserved natural phenomena and their adherence to physical laws.
  • There are suggestions for experimental approaches to investigate sound waves in different environments, such as comparing sound propagation in air versus a vacuum.
  • Several humorous remarks are made regarding the philosophical implications of the question, including variations on the theme of observation and existence.
Participants express differing views on the definition of sound and the necessity of observation for sound to exist. There is no consensus on the matter, with multiple competing perspectives remaining throughout the discussion.
Participants highlight the complexity of defining sound and the philosophical implications of observation in physics. The discussion includes references to the nature of sound waves and the conditions under which they are perceived.
Monaco
I'm trying to put an end this age old question, but I want to translate it into form of an equation.
SOME SAY: No, because "sound" is ears interpretation of those waves.
I SAY: Yes, because it makes a "sound" (as defined by the vibrations). I'm going by textbook definition. It makes sound because sound is a wave vibration of physical matter. Whether or not it gets heard (perceived by ears), that sound still resonates with other medium. (reflects off a tree, hits blade of grass.) To me, that's like End Of Story.
When I read about all the factors of sound being formed, sound in motion, sound being translated through medium... only in the end, in it's final stretch of it's lifespan does the sound get heard or not get heard. To me it's just as cut and dry as the sound wave exists = there is sound. Put a video camera out there. Not only will it give you hard evidence in Dolby stereo, but you can watch the events that caused it.
If y=tree falling and x=sound generated, how would you put into an equation that x is true regardless of the medium of translation?
I never able to find answer for my question which is similar: What is the Sound of the Single Hand?
Put a window out in the middle of nowhere. Have a remote controlled plane break the sound barrier, creating a sonic boom.
Sound waves transmit energy.
Although I don't agree with this, some will say if you put a video out there, it's making it so it's sound all of a sudden. They say it's putting a human like observer that relays it to humans. (Sounds kind of like a debate between Albert Einstein and randomness) They say without the video camera, you have no way of verifying there's actually sound.
Yes I know this wouldn't make sense based on what we know about sound and thus contradicting what we already know, and in addition to that goes against parsimony, but some would still use that argument.
I wonder if you can evaluate how the leaves/dirt around the fallen tree are moved about and then plug in some equations to see if their design match how sound vibrations would dictate, which is a more naturalistic scientific approach, but then you know what the critics will say. They'll say you observed the leaves and dirt! :rolleyes:
There's only one way to prevent anyone or anything from observing the sound. That's to transmit the sound into a vacuum. In that particular instance, I'd have to agree that there's no sound. Of course, then the tree wouldn't be falling in a forest.
@OP:
If a tree falls in the forest and no one is there to hear it does it make a sound?
Well, no one is there to observe. I think you cannot put any measuring device.
Here's an idea, have a lab experiment where you drop a tree and observe how the vibrations moves the dirt nearby vs. dropping a tree in a vacuum in the lab to see how only the impact hitting the ground vibrates the dirt. (leaves probably won't be sensitive enough to air vibrations, need dirt) Then you can get a schema for how air vibrations (sound waves) moves the dirt versus when in a vacuum. That wouldn't test for sound waves traveling through solids, but rather would test for it moving through the air. That would be an experimental-control for figuring out sounds traveling through air, and then could be used to test the real life examples.
If a man says something in the forest, and there's no woman around to hear; is he still wrong?
Good point.
He was goofing off in the forest instead of home mowing the lawn, wasn't he?
Ok, tree fall and either makes sound or doesn't make sound. Explain with an equation.
Yes. Topher = always right.
It's not a deep philosphical question, it's just asking how you define the word 'forest'.
Define sound.
It doesn't become a sound until there is someone or something there to hear it. For it to be a sound, it requires there to be a receiver. Until then, it's just compression waves.
[STRIKE]Define your mom.[/STRIKE]
The tree falling riddle is supposed to be interpreted more deeply, which I thought it would be taken more seriously because this is pertaining to the philosophy of physics. The question can be more directly reworded as
"If we do not observe a specific case of natural phenomena, yet we can predict it based on physical laws we established, does it still follow this law?"
or
"If an electron is not directly observed, does it still have a definite position."
The answer to the latter is commonly answered as No.
That's my thinking. Compression waves wafting through the air do not become "sound" until they react on an ear drum (human or animal) and all of that complicated stuff happens to transform the waves into electrical impulses that the brain interprets as a sound. Until all of that goes on, you've got nothing but waves.
Anb BobG's sonic boom may break the glass window, but that still doesn't make it a sound.
I'm more curious to know where this forest is that has trees but is devoid of all life. :bugeye:
My question would be "is it possible for a tree to fall in a forest where there is no life capable of hearing it?"
Good point. Do spiders have eardrums?
The Tree in the Forrest said:
The rumours of my fall have been greatly exaggerated.
The point of the question has nothing to do with an actual scientific explanation. It is a zen koan. It is meant to question the nature of our perceptions and their relationship with reality. Sort of an ontological paradox. Similar ones are "What is the colour of the grass at night?" and as Sorry mentioned "What is the sound of one hand clapping?"
Conservation of energy
/thread.
If Einstein falls to Bohr, is the Moon still there?
If there are no suitable detectors,observations or any other evidence then any assumptions we make are purely speculative.The majority opinion,including my own,is likely to be that a sound is made,the sound one would normally associate with a tree falling over.Somebody else may claim that the tree was singing Zip-A-Dee-Doo-Dah as it fell.Without evidence no assumption can be proved or disproved.
(It's the truth,its actual everything is satisfactual...to be sung to the tune of Zip-A-Dee-Doo-Dah...:biggrin:)
*-<|:-D=<-< said:
Define sound.
There's no need, it's already defined:
Sound is a traveling wave.
Perception of sound is called hearing.
Here's where I'm going with this...
A cat says: "_____" and a dog says: "______". You just played it in your head right? That proves that we don't need ears to "hear". The hearing part of it is something going on in the brain. The ears can serve to assist the translation of sound waves, but the actually hearing is not dependent on them.
Sorry for taking this somewhat off topic, but I can't resist posting a variant that I recently came across.
If a man makes a statement in forest, and there are no women around to hear it, is he still wrong?
You didn't read the rest of the thread, did you George?
Evidently, if a man posts on a message board and, there's no woman around to make sure he's not goofing up, he's still wrong.
:redface: Yes, my post is the same as post #8 by NeoDevin. Sorry. And it is true that neither my wife nor my three-year-old daughter supervised when I wrote the post.
I first saw this a few weeks ago on a t-shirt worn by my 72-year-old neighbour. He has been married for close to fifty years.
"If a tree falls in the woods, and nobody is around to hear it, and it hits a mime, does anyone care?" - Larson
Agreed.
If we're saying it falls in the forest, then YES is the answer because sound is a traveling wave, and this traveling wave will be observed by something (air, dirt, leaves) therefore it must exist.
But the deeper question is, with no observer (i.e. no dirt, air, etc. to absorb the wave's energy) what happens? No observer means that there is no certainty as to what happened, so who's to say it took the most logical path and created a traveling wave?
  • · Replies 31 ·
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 25 ·
  • · Replies 35 ·
