kos
- Messages
- 14
- Reaction score
- 0
How does movement of the creator of gravity field( mass or energy density) affect the magnetude of exerted gravitational field ! Is there any relation at all ?
Unless you're dealing with an extreme case (neutron stars or worse), or need extreme accuracy, you can work this out roughly using Special Relativity, as the resulting motion has to be consistent when seen from different frames of reference.kos said:How does movement of the creator of gravity field( mass or energy density) affect the magnetude of exerted gravitational field ! Is there any relation at all ?
Olsen said:then we find, with this definition, that M_effective = γ(1+β^2)M. Therefore, in the ultrarelativistic limit, the active gravitational mass of a moving body, measured in this way, is not γM but is approximately 2γM.
(squared brackets my insert for context)pervect said:I'd recommend (as I have in the past when this question [effect of velocity on gravity] has come up) the following paper. http://scitation.aip.org/content/aapt/journal/ajp/53/7/10.1119/1.14280 "Measuring the active gravitational mass of a moving object".
I understand and agree with what you said, but as long as we avoid the term 'force' and also emphasize that it is a specific coordinate acceleration and only valid for r > 2m (which I did not do), I see no harm done. And the equation is so beautifully simple...pervect said:Jorrie: You might get some intuition from the way you're doing things, but it's a bit risky to interpret d2r/dt2" style="font-size: 112%; position: relative;" tabindex="0" class="mjx-chtml MathJax_CHTML" id="MathJax-Element-7-Frame">d2r/dt2 as being due to a "force".
