Does a photon push or pull a massive particle during emission and absorption?
6 replies · 4K views · last reply
kmarinas86
Consider a two particle system:
---- photon ----------- massive particle ---------------------
------- photon -------- massive particle ---------------------
---------- photon ----- massive particle ---------------------
------------- photon -- massive particle ---------------------
---------------- photon massive particle ---------------------
------------------- photon massive particle ------------------
A photon is emitted and absorbed by a particle. I assume that the massive particle would be pushed in the process, however, when the photon is emitted in the opposite direction:
------------------- photon -- massive particle ---------------
---------------- photon ----- massive particle ---------------
------------- photon -------- massive particle ---------------
---------- photon ----------- massive particle ---------------
------- photon -------------- massive particle ---------------
That's perpetual motion! So it has to be wrong.
The alternative possibility I can think of is this:
As a photon approaches a massive particle which will absorb it, it will (pull it in?)
-------------- photon massive particle -----------------------
And then when it is emitted, it will pull it out?
This seems to be more symmetrical, is this what happens? It certainly isn't perpetual motion. But people tell us of radiation pressure, though solar sails must be reflective.
Alternatively, could the photon be emitted in the other direction:
-------------- massive particle photon -----------------------
------------ massive particle -- photon ----------------------
------------ massive particle ----- photon -------------------
------------ massive particle -------- photon ----------------
But then this to is perpetual motion. Advice?
It isn't clear what your diagrams are supposed to demonstrate (or rather, they demonstrate something unphysical: the massive particle should continue moving with constant velocity after the event, and not just be shifted to the side briefly), nor why you think this is perpetual motion, but I'd guess that the root of your error is in presuming that the reflected photon has the same frequency as the incident photon.
Can you write down the equations for conservation of momentum?
Well the photon has no mass, but it does have momentum. Would that be [itex]p=hf/c[/itex], where [itex]p=momentum[/itex] [itex]h=planck's constant[/itex], [itex]f=frequency[/itex], and [itex]c=speed of light[/itex]? We would have then:
[itex]m_i v_i + p_i=m_f v_f + p_f[/itex]
Is there supposed to be more than one equation?
how about conservation of energy. why don't you tell us a little bit more about your "massive particle." Does it have any internal structure or is it just a point?
An Atom.
There are many conservation of energy laws. Also, the outputs are not defined specifically in the problem, so I'm not sure which ones to use.
kmarinas86 said:
An Atom.
no. there are not. there is one law: Energy is conserved.
In your case you will have to take into account whether or not the atom is left in an excited state.
