High School Does a tangent to a curve touch at 2 identical points?
The discussion centers on the mathematical properties of tangents and their relationship to curves, specifically examining the functions y = x - 1 and y = (x - 1)². The tangent touches the curve at x = 1, which is a double root, indicating that the tangent line is also a secant line at that point. The conversation explores the deeper implications of this double solution and the concept of limits in calculus, emphasizing that while secants approach the tangent, they do not become it until the limit is reached.
  • Understanding of polynomial functions, specifically y = (x - 1)²
  • Familiarity with the concept of tangents and secants in calculus
  • Knowledge of limits and their properties in mathematical analysis
  • Basic algebraic manipulation and solving equations
  • Study the properties of polynomial roots and their multiplicities
  • Learn about the concept of limits and continuity in calculus
  • Explore the derivation of tangent lines using differentiation techniques
  • Investigate the relationship between secants and tangents through graphical analysis
Mathematics students, educators, and anyone interested in the geometric interpretation of calculus concepts, particularly those studying polynomial functions and their derivatives.
grzz
The graph of y = x - 1 CUTS the x-axis at x = 1 while the graph of y = x2- 1 TOUCHES the x-axis at x = 1.
The point at which the tangent touches the curve is shown mathematically by having two solutions of x, i.e. x = 1 (twice).
Is there some deeper meaning to these two identical solutions for x?
Mathematics news on Phys.org
It can be even more. The tangent of a straight line is the straight line itself and therefore "touches" it on the entire length.
Yes, there is! A tangent at ##x_0## is the limit you get when you approach ##x_0## by secants, which cut the curve twice - say at ##x_1## and ##x_2##. ##\; x_1 → x_0 \, ,\, x_2 → x_0## will then result in the tangent.
I am very sorry.
I meant comparing the graphs of y = x - 1 and y = (x - 1)2.
Both equations have the solution, i.e. x = 1 but that of the tangent is x = 1 (twice).
I am asking if there is some deeper meaning for that 'twice'.
fresh_42 said:
It can be even more. The tangent of a straight line is the straight line itself and therefore "touches" it on the entire length.Yes, there is! A tangent at ##x_0## is the limit you get when you approach ##x_0## by secants, which cut the curve twice - say at ##x_1## and ##x_2##. ##\; x_1 → x_0 \, ,\, x_2 → x_0## will then result in the tangent.
Thanks 'fresh_42'.
That's the idea that crossed my mind.
But then then when one talks about 'limits' one may say that limits are approached as far as required ... but not attained.
Why not? What is the limit of say ##(5,4,3,2,1,1,1,1,1,1,...)##?
If you solve it by geometrical means, you will find exactly one solution, the tangent. Why do you think calculation will result in a limit that isn't reached? You may calculate secants through the points ##(x_0, (x_0-1)^2)## and ##(x_0+h, (x_0+h-1)^2)## and see what happens if ##h → 0##. But don't forget to cancel ##h## out of fractions when it is possible. It is the same calculation, which has to be made to prove ##y'=2(x-1)## or in general to prove the formulas of differentiation like ##(x^n)' = nx^{n-1}##. (The calculation should be easy if you choose ##x_0= 1## as touching point, but I suggest to keep ##x_0## arbitrary as an exercise.)
Do you know the fly which flies between two approaching trains at twice the speed of the locomotives? One way, then turns and flies back, then turns again whenever it reaches one of the trains. The distance between the trains is getting smaller and smaller, the fly has ever smaller distances to fly until infinity. Nevertheless the fly will die after a finite amount of time when the trains crash.
The limit of the above is 1 and IS attained.
But although one knows the limit of 1, 1 + 0.5, 1 + 0.5 + 0.25, ... yet is it ever attained?
Limits are a way to get mathematically hold on something like arbitrary close. Sometimes arbitrary close is zero, the closest possible way, and often just arbitrary close and the limit isn't attained. Since tangents (if defined) touch their function, they are attained by narrowing secants. But you could still object that the secants (as our sequence) are still straights that cut the function's graph twice, no matter how close these two points are. So we get a sequence of secants that converge to the tangent without being one. However, you asked for the meaning of the double solution at one point. One way to see it is the sequence of secants (with two points) becoming a tangent (with one point as the limit of the two secant points) in the limit.
If I misunderstood it, and you were only referring to the exponent ##2## in ##y=(x-1)^2## then it is more an algebraic than a geometric question.
E.g. ##(x-1)^n## has a solution of multiplicity ##n##.
See https://en.wikipedia.org/wiki/Multiplicity_(mathematics)#Multiplicity_of_a_root_of_a_polynomial
The geometrical description is a good answer to me.
Thanks
  • · Replies 20 ·
  • · Replies 33 ·
11K
  • · Replies 0 ·
