Undergrad Does an inverse Riemann exist?
  • Thread starter Thread starter smilodont
    Inverse Riemann
The discussion centers on the concept of the "inverse Riemann," specifically questioning whether it is possible to invert the limits of a Riemann sum. Participants clarify that the summation symbol ∑ represents a sum, and there is no established notation for decrementing the index from a higher value to a lower value. The integral relationship is also highlighted, where switching endpoints results in a sign change. Overall, the consensus is that the traditional use of Riemann sums does not accommodate this inversion.
  • Understanding of Riemann sums and their application in calculus.
  • Familiarity with integral notation and properties, such as the relationship between limits and signs.
  • Basic knowledge of summation notation and its conventional usage.
  • Concept of mathematical notation and its implications in representing functions and operations.
  • Research the properties of Riemann sums and their approximations to integrals.
  • Explore the implications of changing limits in definite integrals and their effects on results.
  • Investigate alternative summation techniques and their notations in advanced mathematics.
  • Learn about the historical context and contributions of Bernhard Riemann to mathematical analysis.
Mathematics students, educators, and professionals interested in calculus, particularly those exploring the nuances of Riemann sums and integrals.
smilodont
I already googled this but I did not find a definite answer. Is there such a thing as a 'inverse riemann'? Specifically, where you invert the start number to be at the top of the riemann symbol and then decrement down to the end value which is on the bottom of the riemann symbol?
Thereis nothing special about the integral you described. Switching the end points simply means changing the sign of the integral.
Ok, explain what you mean. I had never seen that before.
Do you mean ##g(x):= \int_a^x f(t)dt ## , where x is a variable?
\int_a^bf(x)dx=-\int_b^af(x)dx
Smilodont: The name "Riemann" is associated with so many concepts that it would help a lot if you spelled out what you mean in some detail.
∑ is a riemann. You pointed out an integral. They are similar but not the same. I am talking about the riemann sum. hope that clarifies.
Riemann sum is used as approximation to Riemann integral. In that context what exactly is your question?
i am interested in the ∑ use. i was confused in calling it a riemann sum. too long since college. it's a summation symbol. what i was interested in is if you can put the higher value on the bottom and lower value on the top. If so, is that viewed as indicating you wish to decrement from the value at the top to the value at the bottom?
smilodont said:
∑ is a riemann.
No, the symbol ∑ represents a sum or summation. As far as I know there is no such thing as "a riemann," short of being a reference to someone with that name.
A summation typically looks something like this:
$$\sum_{j = 1}^n a_j$$
The index starts at the value at the bottom and increases up through the upper value above the summation symbol. I've never seen a summation where the index was decremented, and I don't think there is any commonly used notation to indicate this.
13K
