- 4,867
vanhees71 said:Hm, in my understanding, causality implies a specific time-ordering. In fact it's the only sense you can give to specific time-ordering, and thus causally connected events cannot be space-like separated. In other words event A can only be the cause of event B if it is time- or light-like separated from B and B is within or on the future light cone of A. It's not clear to me, how you define causality to begin with.
PeterDonis said:The same way you've been defining it (you sometimes use the term "microcausality", but sometimes not): that spacelike separated measurements commute. But now you seem to be shifting your ground and giving a different definition of "causality" (the one I quoted above), the basis of which in QFT I don't understand (which is why I asked about it).
Causality is generally defined as the universal law that causes must preceed effects in every frame of reference, and it entails nothing more. In contrast to locality, a notion with multiple, partially conflicting uses, one cannot tamper with the content of the concept of causality without misrepresenting much of classical and quantum physics.PeterDonis said:Not if you give it a precise definition, such as "operators at spacelike separated events commute", no. Which is why I've repeatedly suggested that we should all stop using vague ordinary language and start using precise math, or at least precise definitions that refer to precise math, as the one I just gave in quotes does. Then we can stop arguing about words and start talking about physics.
If you define "locality" as "does not violate the Bell inequalities", then QFT is not local. If you define "locality" as meaning the same thing as "causality" does above, then QFT is local, but you've also used two ordinary language words to refer to the same physical concept, plus you've thrown away the usual way of referring in ordinary language to another physical concept.
In any case, once again, can we please stop using vague ordinary language?
Causality is a precise notion to the extent that cause and effect are precise notions. In physics, cause and effect are made fully precise in the context of dynamical systems. Here changes in the initial conditions of a differential equation at some time ##t_0## are the causes, and the resulting changes in the trajectory for times ##t>t_0## are the effects caused by these changes. Lorentz invariance then implies that the causes of an effect at some spacetime position ##x## must lie in the past cone of ##x##, and that the causes of an effect whose definition involves the spacetime positions from some set ##X## must lie in the union of the past cones of the points in ##X##.
The operational content of causality are expressed in terms of response functions - which embody the notion of causality in their definition - through the so-called Kramers–Kronig relations and resulting dispersion relations. In this form, the notion of causality extends to dynamical systems with memory. In quantum field theory, causality is rigorously implemented through [URL='https://www.physicsforums.com/insights/causal-perturbation-theory/']causal perturbation theory[/URL], where the dispersion relations are the essential tool that ensures a perturbationally well-defined finite and manifestly covariant renormalization process. In the operator apprach to quantum field theory, causality is implemented through the causal commutation relations of fields - i.e., the commutativity or anticommutativity of the field operators at spacelike separation. The fact that cusal commutation rules hold is called microcausality.
Operationally, the causal commutation relations assert (roughly) that states with prescribed field expectations at ##x_1,\ldots,x_n## can be prepared independently by causes near ##x_1,\ldots,x_n## whenever ##x_1,\ldots,x_n## are mutually spacelike separated. This is meant by causal independence.
Simultaneously, they express certain local independence properties. This is the reason why causal commutation relations are - in my opinion somewhat misleadingly - also referred to as local commutation relations, though there is nothing local about them as the relations involve two distinct spacetime points.
