Could Neutrinos Be the Key to Understanding Dark Matter?
  • Context: Graduate
  • Thread starter Thread starter WhiteKnights
    Anti-matter
The discussion centers around the nature of dark matter and the possibility of dark antimatter, exploring theoretical implications, particle interactions, and the current understanding of dark matter's properties. Participants engage in a mix of speculative reasoning and technical arguments related to astrophysics and particle physics.
  • Some participants propose the existence of dark antimatter that does not interact with ordinary matter, questioning if this relates to baryon asymmetry.
  • Others argue that dark matter does not interact via electromagnetic forces, suggesting that if dark matter is non-baryonic, it cannot have an antiparticle.
  • There is a discussion about the nature of dark matter, with some suggesting it could be ordinary matter that is too cold to detect, while others propose it consists of unknown particles that do not emit light.
  • Some participants mention the "WIMP miracle," which posits that dark matter and its antiparticles could have been produced in equal numbers and annihilated over time, raising questions about the potential for dark matter to be its own antiparticle.
  • There are claims that uncharged particles can have antiparticles, leading to further speculation about the properties of dark matter and dark antimatter.
  • A participant suggests that if dark matter were to exist, it might have its own set of particles, such as dark quarks and dark leptons, which would interact with each other but not with ordinary matter.
  • Some express uncertainty about the existence of dark matter itself, emphasizing that current understanding is based on indirect evidence rather than direct observation.
  • Participants discuss the implications of annihilation events between dark matter and dark antimatter, suggesting that such interactions could yield observable effects.
There is no consensus on the existence of dark antimatter or its properties. Multiple competing views remain regarding the nature of dark matter, its interactions, and the implications of potential antimatter counterparts.
Participants acknowledge the speculative nature of the discussion, highlighting that the true nature of dark matter is still unknown and that current theories are based on indirect evidence and assumptions that may not hold true.
WhiteKnights
I imagine it must...Could we have dark anti-matter in our universe that doesn't interact with ordinary matter?
Would this example say Baryon asymmetry?
Space news on Phys.org
Dark matter doesn't interact by the electromagnetic force, thus is not charged. Hence there is no such thing as dark anti matter.
dark matte is a form of ordinary matter as u said ,,,,just interact gravitational forces
right?
Wow,I forget the basic definition, thinking of something more complex...
We don't know what dark matter is made of right?
There are anti neutrinos and anti neutrons.
Do you mean that if dark matter is non-baryonic you can't have anti dark-matter?
Presumably only particles with spin can have anti particles?
There are two main theories, cold dark matter is ordinary stuff ( gas, dust, rocks) that is too cold and dark to see but still has a gravitational effect, because we can model the formation rate of material from the bigbang quite well it doesn;t look like there could be enough of this.
Hot dark matter (or non-baryonic) is unknown particles that don't have electromagnetic effects so don't give off light. This looks more likely, but there is always a danger of coming up with a solution that involves being able to 'make up' whatever properties you like for your solution.
Astrophyiscs measured gravitational effect of dark matter
surround the galaxies right? as the gravitational lenses
I don't know if you would call a gravitational lens an electromagnetic effect.
Perhaps I phrased it badly - dark matter doesn't generate light and doesn't seem to effect the properties of light passing through/near it, so we cannot see it directly - hence dark.
So what's an antineutron? Antihydrogen? And like someone else said, antinetrino? OK, so the first two have internal components which are charged, but having charge is not the requirement for having an antiparticle, antimatter has all quantum numbers reversed, including charge if applicable.
If dark matter is made of supersymmetric particles, then I'm pretty sure those have antiparticles just like normal matter does. A quick search for "anti-neutralino" (my favourite DM candiate) on Google throws up several scientific papers, so I didn't sleep through my supersymmetry lectures and dream it! Of course, it might not be supersymmetric particle, but we can't say for sure whether the type of particle dark matter is made of has an antiparticle until we know what it is!
As for matter/antimatter asymmetry, I presume it must either be all dark matter or all anti-dark-matter or it would have annihilated by now. I presume any asyemmetry would be through pretty much the same mechanism as the matter/anitmatter asymmetry in normal matter, so I would be very suprised if the DM was all antimatter.
what i meant it that the dark matter has a gravitational effect on light...
not electromagnetic effect...(by stimulating electrons if electrons exist in dark matter)
just like when a light beam passes near to a star or
his path will be curved for a little...so what can we say about a galaxy?
am i right?
if there's antimatter, there should be anti dark matter
Antimatter is exactly the same as matter except it has the opposite electrical charge. Since Dark Matter seems to have no interaction with electrical charge, it cannot have an opposite electrical charge. The answer would seem to be, no.
Uncharged particles can have antiparticles.
This is all speculation. No one knows what dark matter is. Until we find it, there isn't even any direct proof that it exists as we have only "seen it" from the effects which most attribute to it (rather than some modified gravity theory).
Since know one knows what it is, (or even, some small groups might argue, if it exists), no one can tell you if there are dark-matter anti-particles as we don't really know how to begin to argue what that might mean.
Anti-what?
We know what dark matter does and what it cannot be but we don't know what it is.
There's an argument called the "WIMP miracle" that can explain the amount of dark matter present in the universe today if dark matter particles and their antiparticles were produced in equal numbers and have been annihilating ever since, provided the particles have a weak-scale mass and cross section. So it's plausible that there's equal amounts of dark matter and antimatter. But the argument also works if the dark matter particle is its own antiparticle, which is a strong possibility given that these particles can't be charged. It's all speculation, though, until we find out what dark matter really is.
Absolutely yes...
In fact, people have used the possibility that dark anti-matter/matter exists to put limits on what it might be. Start at page 73 on this paper
http://arxiv.org/PS_cache/hep-ph/pdf/0404/0404175v2.pdf
The idea is that if dark matter was particle X, some of it must be particle anti-X, and therefore we should see gamma rays or positrons from X and anti-X annihilating each other. If we go out looking for these gamma rays or positions, and we see them, they we figure out what it is. If we don't see them (which we don't), we can figure out what dark matter isn't.
My rough guide is that stuff you see in the night sky all lit up is about 4% of the mass of the universe, and it's all baryonic.
Other baryonic stuff you can't see is cold , like black holes, dark stars, lone planets , asteroids, shrapnel, and gas. About 8%.
Then there's hot dark matter - mostly neutrinos. Some mass but probably a small percentage.
Unknown dark matter about 12%.
dark energy about 70%.
My thoughts are that there is Matter/Antimatter and yes, Dark Matter/Dark Antimatter. My thought on that is that Dark matter has its own set of quarks and bosons. So there would be Dark Leptons, Dark Mesons, Dark Baryons, Dark Bimesons, Dark Barymesons, Dark Trimesons and Dark Dibaryons. Matter/Antimatter DIRECTLY interacts with Matter/Antimatter. Dark Matter/Dark Antimatter DIRECTLY interacts with Dark Matter/Dark Antimatter. My own (strongly disputable) theory on annihilation is that when a particle interacts with its antiparticle, the annihilation yields a decay series of particles of the opposing kind. e.g. a Proton interacts with an Antiproton, the Matter yield is nothing, but Dark Matter yield occurs (not a Dark Proton and Dark Antiproton, but can't rule out the possiblity).
Why? Do you have any science to back up that statement?
It does seem that when a dark matter particle meets its anti-particle, both would be annihilated.
One of the more popular proposals for dark matter is the lightest (therefore stable) neutralino of supersymmetric models. In such models, the neutralino is its own antiparticle.
they found positrons by using the Earth's magnetic field and looking at the aura borialus
so anti
matter could exist
so anti
matter could exist
Antimatter does exist. Are you referring to an antiparticle to dark matter?
wouldnt the antiparticle be white matter
or photons
or photons
I've never heard of "white matter". Are you talking about normal matter that compose you and I and most of the visible universe? If so, then no, it would not be that. Normal matter has it's own antiparticles. And photons are their own antiparticle, not one to dark matter. It is thought that dark matter doesn't even interact via the electromagnetic force, so photons wouldn't even be able to interact except through gravity with dark matter.
oh okay so would black wholes be dark mater
No. Instead of randomly suggesting different things as dark matter you should read up on it a little bit. Hit up wikipedia and search for dark matter on it.
faraday rotation could have some effect to the optical properties that we see, is it known if z-pinches could produce lensing effects?
Hypothetically. On the assumption that dark antimatter exists. If it does and if we could trap it, would it then be possible to use it as an energy source by making it interact with dark matter? How destructive could that be? and what other consequences might there be?
The other hypothetical question that led to the above one is as follows: "Is it possible that antimatter is the source of the limit to the speed of light?
My thoughts regarding the above questions relate to finding a method of exceeding the speed of light for the sake of space travel some time in the future.
  • Featured
  • · Replies 16 ·
