Does Entering a Black Hole Speed Up Universal Aging?
43 replies · 7K views · last reply
rootone said:
Evaporation due to Hawing radiation is proportional to the size (mass) of the black hole.
It could be nearly instantaneously or it could be trillions of years.
Actually, it is inversely proportional to the square of the mass.
rootone said:
According to relativity, the infalling observer notices nothing particularly strange locally while crossing the event horizon.
Locally, (his own frame of referance), other material would be infalling too,and not at unreasonable velocities, and his clock still ticks at one second per second.
He would ceetainly notice the effect of extreme gravity (spaghettification), in the case of a stellar sized black hole,
but for a supermassive black hole that would be lest drastic.
This is all correct.
rootone said:
In any event though he becomes eventually causally disconnected from whatever happens outside of the event horizon.
It is no longer for possible for information to be received by him from 'outside' , and he no longer transmit information to 'outside' either.
This is not correct. The infaller can receive information from the outside at a 'normal' rate until they reach the singularity. It is true that they can't transmit to the outside.
PeterDonis said:
But this would mean that you would never actually fall into the hole--that is, you would observe it evaporating as you fell towards it, and it would disappear before you reached its horizon. As PAllen noted, the unambigous prediction of semiclassical QFT + GR is that this is not correct
I'm just as confused as the OP. The geometry of the black hole may allow for you to pass through the EH relatively unmolested (at least in the case of supermassive black holes), but the equation describing time dilation as you approach it looks pretty unambiguous itself - it appears that the universe, and the black hole you are trying to fall into, should both functionally evaporate as you attempt to cross the boundary.
What we are asking is, why ISN'T this the case, when the basic equation describing time dilation around a black hole seems so unambiguous? What part of the theoretical framework is preventing it from dilating you into a future where the BH no longer exists?
@PAllen
OK, I got about 8/10 there, not too bad, but thanks for further clearing things up.
Asher Weinerman said:
PeterDonis, I'm no expert as I've stated before, but Hawking Radiation evaporates black holes in finite time (approx. 10^68 years or something) - this is not my personal theory - many sources quote this estimate or 'round about. If you can tell me how long it takes to fall through the horizon from, say, r = 3m, and its not infinity, please do it.
And don't threaten me again about being off-limits - most of us here are searching for information and trying to understand things through conversation, while others just act as know-it-all bullies and they are the ones that should be off-limits.
You made a definite statement (not asked a question), and that statement is considered simply wrong by experts.
In another recent thread, many references and explanations were given to you. There is no point in repeating them all here.
As for your question, you should know that it fundamentally ambiguous in even special relativity. How long does it take a muon to reach the ground on creation in the upper atmosphere? It depends on who is measuring and how. However, invariant is that it reaches the ground. How long an infaller takes to reach the horizon and then the singularity has one type of answer that is invariant: the time on the infaller's watch, which is quite short. Otherwise, time for an external observer depends only on coordinates chosen and can be short and finite or infinite depending on coordinates. The infinite value has the same content (or lack of it) as the statement that a ball dropped from an accelerating rocket never gets beyond the Rocket's Rindler horizon. This is just a matter of the choice of coordinates by the rocket. They can choose different coordinates and get different answer. However, the fact that, say, a dropped ball collides with some planet is invariant irrespective of coordinates (though ill chosen coordinates may not include that event).
The competition between evaporation and collapse can be modeled quantitatively, and relevant papers were provided to you in the other thread that establish that the horizon forms, and object fall through it, before evaporation occurs.
And objects also fall into the hole in finite time. See below.
The part about black hole evaporation taking a finite time isn't, true, but you are stating it in a way that does not give me confidence that you understand what it means.
However, your statement that the hole will evaporate before anything can fall into it, since you have continued to repeat it in the face of repeated demonstrations as to why it is incorrect according to mainstream science, is a personal theory. That's what I was responding to.
Sure. It will take a time ##\tau = 2m \left[ (r / 2m)^{3/2} - 1 \right] \approx 2.67m##. (Note: edited to correct the formula.)
I wasn't making a threat. I was reminding you of PF policy about personal theories. You will not get another reminder.
Your error is: "he basic equation describing time dilation around a black hole seems so unambiguous". This is false. Time dilation is coordinate dependent, NOT unambiguous. Redshift/blue shift measured by a particular observer is unambiguous, but simultaneity is not unambiguous. If you use coordinates that cover the horizon the interior and exterior of a collapsing body, you can model the competing processes and find that collapse and infall occur way before evaporation.
jimmycricket said:
I'm not sure if anyone has answered the question yet as I don't have the background to even begin to understand some of the concepts presented here. I see a lot of people talking about what you would observe while inside the black hole. What I was trying to get at is not what one would observe but what actually happens to the universe outside of the black hole during the time that would elapse between crossing the event horizon and reaching the singularity.
Not much at all.
Depending on the size of the black hole, you'll fall through the horizon to the central singularity in anywhere between a few tens of microseconds to a few hours. That's not enough time for the universe to do anything interesting while you're falling in. (I've wasted that much time over a few nice cups of coffee, and the universe never does anything interesting while I'm drinking coffee).
Observers outside the event horizon won't be able to see you crossing the event horizon and reaching the singularity, so the phrase that I've bolded above isn't meaningful to those observers and the question makes no sense to them. But that's their problem, not yours.
Can you give the specific equation you are referring to? I suspect that you will find that it is an equation for the time dilation of static observers--i.e., observers who are hovering at a fixed radius above the horizon. You can't use that equation to draw conclusions about what happens to infalling observers.
t2=t2/1-(rs/r) where rs is the Schwarschilde radius.
So there you have what amounts to a pretty clear infinite progression as you attempt to reach the horizon. The naive assumption is that you'd be prevented from ever reaching it. This is clearly not what most astrophysicists believe happens under the current set of theories, but I haven't been able to dig deep enough to figure out why as yet. This equation is useful only for a 'static' observer? What would the correct equation for an infalling observer be?
This formula, as I suspected, only applies to static observers. It does not apply to infalling observers. That is why you are getting incorrect conclusions from it.
For an observer that falls from a radius ##r## that is above the horizon, the proper time for him to reach the horizon is given (at least to a very good approximation) by the formula I gave in post #35: ##\tau = 2m \left[ ( r / 2m )^{3/2} - 1\right]##. If you take away the ##-1## inside the brackets, you get the formula for the proper time for the observer to reach the singularity at ##r = 0##.
Note that I said "proper time". That is, the formula gives the time elapsed on the infalling observer's clock. That is the only invariant meaning of "time" that there is. But one can also use a coordinate chart, called Painleve coordinates, in which this time is also coordinate time, so you can use the simultaneity convention of these coordinates to assign "times" to spatially separated events. These coordinates cover the horizon and the region inside it, as well as the region outside, so it is a much better choice than Schwarzschild coordinates for analyzing scenarios like the one under discussion. The figure quoted earlier of ##10^{68}## years for a stellar-mass hole to evaporate by Hawking radiation is really given in Painleve coordinates, not Schwarzschild coordinates, so it clearly is much, much larger than the time for an observer to fall through the horizon, which is on the order of ten microseconds for a stellar-mass hole.
DaleSpam said:
it is about 3.993 m.
Just a note, this is a more accurate answer than the one I gave in post #35. The formula I used there is for an object that starts from rest at infinity, so at any finite radius, it is falling inward with some nonzero velocity. That is a reasonable first approximation for an object that starts from rest at a finite radius, but the formulas in the mathpages article you linked to give the exact solution for that case. I was just too lazy to look it up, since the key point for this discussion is that the answer is finite. :wink:
Well that's enough time to listen to a couple of pop songs, so it's not too bad.
I suggest this one:
