Does Light Have Mass? Astrophysics Discussion
  • Context: Undergrad
  • Thread starter Thread starter Young Seeker
    Light Mass
59 replies · 6K views
Young Seeker
I am new in this forum, and I'm just getting started. I am a very big admirer of astrophysics and I'm seeking answers and at the same time proposing new possibilities for some of the awesome mysteries of the universe. I'm young, so sometimes there is a great possibility tht i might add some stupid ideas, please understand and forgive me on such occasions :)
Ok, so to my first question,
Does light have mass?
I have thought a lot abt it and i can't find a better view to see light as a unique, not yet identified substance, which can at some conditions exhibit mass, and at other conditions, massless
Please share ur views abt this...
Welcome to PF! First and foremost, I think you should understand that PF's primary goal is to help people understand physics as it is currently understood and practiced by mainstream professional scientists. Personal ideas and theories are not usually acceptable here because they typically run counter to the mainstream view and thus counter to PF's primary goal.
So while we can help you understand why light is massless according to current science, we cannot discuss any personal ideas you may have on it.
So to answer your question, light is massless when it exists as a freely propagating electromagnetic wave. I've heard of strange things happening when light travels in certain mediums, but as far as I know these phenomena are not described as normal light, but as an interaction between the EM wave and the medium giving rise to these effects. For the vast majority of cases you can consider light to be massless.
ok, thanks for the reply, but can u tell me how can an objest, being massless interact with something that has mass? ( I'm talking about light getting reflected off a surface)
First of all, what rule is there that something must have mass for it to interact with something that has mass? Do you think an electric field has a mass? After all, that can interact with anything with a charge.
It is a good time here to re-examine your assumption.
Zz.
Why would you think that they could not? Physics is a descriptive science where we introduce theories that describe what we can observe and we observe that light interacts with matter so naturally we create theories where this happens. We do not seek any deeper philosophical reason. Then you can of course ask why they interact in a given theory, in the case of light it is described by Maxwell's equations and the Lorentz force law.
Sure. Light is an Electromagnetic wave. This means that light is a fluctuation within the EM field. What's fluctuating you may ask? The answer is something we call a "field vector". A field vector is a mathematical way of describing how a charged particle will interact with a field. In the case of the electric field, this field vector tells us which way the field is pointing and what the magnitude of the field is at this location. In other words, a field vector tells us which way a charged particle will move in response to the field and how much force is applied to the particle by the field.
Since an EM wave is desribed as a fluctuating field vector, this means that the wave exerts a force on a charged particle that alternates in direction and varies in strength as the wave passes over it the particle.
In other words, light is an EM wave of alternating force that acts on charged particles. No mass is required for the EM wave to interact with matter.
Interactions have very little to do with whether or not something has mass, and more to do with whether or not it has charge. Photons are the carriers of the EM force so they interact with things that have EM charge. Gluons are the carriers of the strong force, so they interact with things that have color charge. And so forth.
hmm, thank you very much guys, for your useful feedbacks :)
That depends on the specific conditions. Due to
[tex]E^2 = m^2 c^4 + p^2 c^2[/tex]
light is massless for p=E/c (e.g. in the case of a single photon). Otherwise (e.g. in the case of a stationary radiation field) it has mass.
PeterDonis said:
Can you explain?
Let's take a very simple example: Two photons with equal energy moving in opposite directions. This system has energy but no momentum and according to the equation above it's mass is m=E/c². Light is only massless if all photons are moving in the same direction. In any other case it has mass.
In what practical context would you ever consider this 2 body system together rather than simply treating the photons individually? This is not a bounded system, so I don't see how one could, for example, apply a force to the center of mass of this system.
I would plot the event rate as a function of this "mass" in the ATLAS and CMS detectors, to find the Higgs. But the invariant mass of the two photons aside, this does not mean that the photons (or light) has mass.
You mean collide the two photons and hope they have enough energy to produce a Higgs? Seems unlikely even if the two photons were both gamma rays...and what if the two photons don't have enough CoM energy to produce a Higgs?
In addition, I have no idea what this has to do with the "mass" of the 2 photon system?
Put the photons into an ideal mirror box.
So then you've created a bounded system. I have no problem with that and calling it the mass of the bounded system, box+photons. This is the same concept as a hydrogen particle in a higher energy state should have slightly more mass than a hydrogen particle in a lower energy state. Or that a hot box is slightly heavier than a cold, identical in every other way, box. However, I don't see any practical reason to consider two free photons traveling in different directions as one system (in particular, to consider the invariant mass of such a system), but I can of course be missing something!
The Higgs was discovered mainly in the decay channel ##H\to \gamma\gamma##. By observing the photon pairs and computing their invariant mass, an excess over background was found around 125 GeV. Of course, this is the mass of the Higgs, not the mass of the photons, but it does have physical significance even if the photons are not bound.
Ah, ok. Was this sort of thing what you meant by a "stationary radiation field"? I ask because an actual radiation field doesn't have a description anything like this; what you've described is a highly idealized system.
You mean by computing the CoM energy and then setting ##m\equiv E_{com}/c^2##?
EDIT: I guess I should have been clearer in this question. I meant, did they somehow find the invariant mass of the system of both photons (in one measurement), or did they find the Energy of each individual photon separately, but in the center of mass frame and simply do the above calculation?
In other words, were the 2 photons treated as a system, or treated separately, but in one inertial frame?
Yes.
No, clearly you have to measure the photons separately. However, from those measurements you can obtain the invariant mass of the two-photon system (in fact, both collaborations have used ##m_{\gamma\gamma}## as the label of their x-axis). This is of course a property of a system of any number of particles (as long as everything is not moving in the same direction, the total 4-momentum will correspond to an invariant mass, the CoM energy) and a photon gas is going to be different from a gas of massive particles (unless the massive gas has a temperature high enough for the mass to be irrelevant) in the sense that its pressure is going to be comparable to its energy density.
I mean a radiation field without momentum. A practical example would be the black body radiation inside a hollow body. The full energy of this radiation contributes to the mass of the system.
Ok, but this only works because the radiation is confined by something that isn't radiation, so that the system as a whole (a) is bound, and (b) has a well-defined rest frame in which its net momentum vanishes.
As a physical model, this is fine; but as a response to the OP's question, I think it's a little misleading. The fact that light (or radiation in general) can be one component of a system that, considered as a whole, has nonzero mass, does not mean light, considered as a fundamental thing, has nonzero mass. The electromagnetic field is a fundamentally massless field, and that doesn't change when it's part of a system.
Using the invariant mass defined by the relation ##E^2 = (mc^2)^2 + (pc)^2##, the mass of a system generally does not equal the sum of the masses of its components. Radiation confined in a container is one example of this.
In case of the cosmic background radiation it works without confinement.
Yes, in the sense that at any event there is a local "rest frame" in which the CMBR is isotropic. But you can't extend that globally because of the universe's expansion.
You don't need to extend it globally. Just select a finite volume. There is always a frame of reference where the containing background radiation has no momentum but there is no frame of reference where it has no mass. That's not limited to background radiation or black body radiation. It applies to almost every radiation. Light without mass is an exceptional case (e.g. single photons or laser) or just a good approximation (e.g. for sunlight).
No, there isn't, because if you select a finite volume that's large enough for spacetime curvature to be significant, there is no well-defined "momentum" at all. Defining "momentum" for an extended system (and hence defining an overall 4-momentum vector for the CMBR, so you can take its invariant length and verify that it's nonzero) requires flat spacetime--or at least asymptotically flat spacetime. The universe, on distance scales large enough for curvature to be significant, is neither.
(Also, you haven't responded at all to the main point of my post #23, which is that the EM field is a fundamentally massless field, and that's what the OP was really asking about.)
Orodruin said:
Yes.
Then it seems more like a mathematical construct rather than a concrete "thing" (mass) that we are used to. Of course, this is beginning to head over to the philosophy side, so I'll just drop it. ;)
I have done this in positron emission tomography (PET). The momentum of the electron-positron pair is conserved in the photon pair. This results in a small deviation from the ideal line of response and is one of the fundamental factors limiting the spatial resolution of PET (although not the dominant factor).
