Chris J
- 21
- 3
- TL;DR Summary
- Many say water freezes at 32F / 0C even if it's moving. Is that correct?
When water is moving does the actual freezing temperature change or does steam etc not freeze because warmer water keeps getting brought to the surface?
Or is there something else going on that lowers the freezing point as long as the water is in motion?
There are several reasons for my curiosity but the main ones are :
The first would be fog that doesn't appear to freeze when I would expect it to. My understanding is humidity/fog is water droplets in the air rather than it being in gas form. So shouldn't it freeze around 32F / 0C? Yet it doesn't seem to freeze even well below that.
Second, I stopped covering my swimming pool in the winter and instead, let the pump run continuously until the water was very cold and all of the leaves had fallen. I then disconnect it all and drain it and pretty much that night the pool freezes. When I do this the water temperature is usually very close to 32F. One year I had the water just a few tenths above 32F and I became very nervous because I thought once the water hit 32F the entire pool would become a block of ice since it's all circulating and mixing thus no warmer water below the surface. Perhaps this was a ridiculous fear? Will water in a large tank being circulated freeze at or close to 32F / 0C or does the movement lower this?
If movement does lower the freezing point why is this? What's going on to cause it and how much of an effect does it have?
