Does my elongation vs. load graph look right?
In summary, the conversation discusses the graph of a bungee cord being tested by adding load to one end while fixing its other end. The x-axis data is obtained by measuring the elongation for every pound of load added. The y-axis represents the load, which goes up from 1 to 25. However, there is confusion about the orientation of the graph and whether it accurately represents the behavior of the cord. Suggestions are made to switch the axes and measure the tension force at different elongations to get a more accurate graph. It is also mentioned that there is a difference between engineering stress and real stress when plotting the graph. Finally, a mistake in calculating elongation is pointed out, which could be the cause of the strange graph
physicsss
319
This is a graphfor a bungee cord that is being tested by adding load to one end while fixing its other end on some support system
how I got the x-axis data: So say the initial length is 2 cm and after one pound is added to it it became 2.50cm. So I use 2.50cm-2cm and use it to find the elongation. so (0.5, 1) is the first point. and so on. I do the elongation measurement for every pound of loud I added.
y-axis is load. it goes up from 1 to 25.
But my graph here doesn't look right at all...is it supposed to go left to right and not left to right and left? Or it is the case with bungee cords? Please help...
TY.
Given that you've taken the load as the variable, and the elongation as the function of the variable, you get a graph of elongation as a function of load, and not load as a function of elongation. If you switch the axes (put the load on the x axis, and the elongation on the y axis), then it will make more sense. But I'm not sure how useful such a graph would be.
If you want to study the cord's mechanical behavior, you need either a load-elongation graph (load as a function of elongation), or a stress-strain graph. The former tells you how this specific cord behaves, while the latter tells you how the cord's material behaves regardless of the shape of the actual cord.
To get these, first meassure the load as a function of elongation: stretch the bungee cord by a known amount, and measure the tension force it produces. Repeat for as many elongations as you need (in materials investigations, this is usually done until the model breaks).
Then, if you want the stress-strain graph, divide the load by the cord's initial cross-section area, and the elongation by the cord's inital length. I think you should get a graph similar to that of a typical elastomer.. I'll post a link to a sample graph in a few minutes.
edit:
ok. http://www.padtinc.com/epubs/focus/2002/0012_1125/article3_imgs/img001.gif , which gives a survey of the various elastomer testing techniques.
It's also important to distinguish between "real stress" and "engineering stress".
Anyway physicsss, according to your graph, as you increase the load from 6 lbs to 7 lbs, the bungee cord gets shorter, and continues getting shorter as you add more load. Is this what really happens ? Also, you say that the first point was at (0.5,1) but on the graph, it's at (0,1). Will you please confirm that the cord gets shorter as you load it, finally returning to nearly its original length of 2 cm at 25 lbs ?
how else can I calculate elongation? that point was made up to show what I did to get the calculations...the cord gets longer from 2 cm to 2.50 cm, but the elonation is the difference between the two, or am I doing this wrong?
Physicsss, Gokul was pointing out that your graph shows that with increasing load, the cord extends reasonably steadily to a certain value, and then with even more load, it starts to contract back, eventually to its original size. I don't see how this happens.
Perhaps you want to try plotting a better graph? Define strain as extension/original length, and define stress as force/cross-sectional area, and feel free to neglect the change in area with extension as you see fit. Then plot stress/strain.
True. My description above was for engineering stress (and engineering strain), I don't really think the OP needs the real stress to real strain graph..
The elongation is the current length minus the original length, not the current minus the previous.
Nice catch alpha. I think you have debugged the problem with the weird graph. The y-integral of that graph will look more like a regular load elongation curve, so I think you've cracked the source of the negative mudulus.
1. What is the expected shape of an elongation vs. load graph?
The expected shape of an elongation vs. load graph is typically a linear relationship, where the elongation (or strain) increases proportionally with the applied load. This indicates a material's ability to withstand stress without permanent deformation.
2. How can I tell if my elongation vs. load graph is accurate?
An accurate elongation vs. load graph should have a consistent and linear relationship between the two variables. Additionally, the slope of the line should correspond to the material's known properties, such as its Young's modulus.
3. What factors can affect the shape of an elongation vs. load graph?
The shape of an elongation vs. load graph can be affected by various factors, including the material's composition, temperature, and loading rate. It is important to carefully control these variables in order to obtain accurate results.
4. Can my elongation vs. load graph be used to determine the strength of a material?
Yes, the elongation vs. load graph can provide valuable information about a material's strength and ability to withstand stress. By analyzing the slope of the graph, one can determine the material's Young's modulus, which is a measure of its stiffness and strength.
5. How can I improve the accuracy of my elongation vs. load graph?
To improve the accuracy of an elongation vs. load graph, it is important to carefully control the testing conditions and ensure that the data is collected and analyzed properly. It may also be helpful to conduct multiple tests and average the results to reduce any potential errors.
  • Mechanical Engineering
  • STEM Educators and Teaching
