Does Negative Mass Have Physical Significance in Modern Theories?
  • Context: High School
  • Thread starter Thread starter snoopies622
    Mass Negative
The discussion revolves around the concept of negative mass and its potential physical significance within modern theories. Participants explore the implications of a computer simulation involving a spring that results in negative rest mass and energy, questioning whether such scenarios have any physical meaning or relevance in contemporary physics.
  • One participant describes a simulation where a spring results in negative mass and energy, questioning the physical meaning of this outcome.
  • Another participant asserts that the mathematical consistency of the simulation does not imply physical significance.
  • Some participants note that while there are no explicit physical laws forbidding negative mass-energy, it has never been observed and its properties would be unusual.
  • A participant challenges the notion of negative mass-energy, stating that a particle cannot give off more energy than it possesses, which is forbidden by physical laws.
  • Another participant references an article discussing negative energy, suggesting it may relate to the original simulation but acknowledges the complexities involved.
  • One participant critiques the term "negative energy," suggesting it is misleading and emphasizes that it does not align with the original definition of negative mass-energy presented by the OP.
  • Concerns are raised about the credibility of popular science articles as sources for serious scientific discussion.
Participants express differing views on the existence and implications of negative mass-energy. Some agree that negative mass-energy has not been observed and may not have physical significance, while others suggest that the absence of a prohibition does not rule out its theoretical existence. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the limitations of definitions and the potential for misunderstanding terms like "negative energy." There is also an acknowledgment of the lack of empirical evidence for negative mass-energy and the complexities surrounding its theoretical implications.
snoopies622
Yesterday I wrote a simple computer simulation for a spring which, when released, sends two masses flying in opposite directions, and views the event from two different reference frames. My goal was just to convince myself that relativistic mechanics is self-consistent and indeed every time I changed the parameters, both momentum and energy were conserved in both reference frames.
But without realizing it at first, the program allowed for cases where the spring sent the masses flying away so fast that the spring itself was left with negative rest mass. But even in these cases, the results were consistent - both momentum and energy were conserved in both reference frames. The spring had negative mass (and negative energy), and its momentum was negative too, meaning (I guess) it was positive but in the opposite direction from which the spring was moving.
My question is: Does this have any physical meaning? Is there a modern theory or theories in which a particle gives off more energy than it has, and is left with negative mass, negative energy, carrying negative momentum, and so on?
No. The fact that the math happens to work out in the particular case you considered does not make it physically meaningful.
As far as I'm aware, there are no physical laws that expressly forbid the existence of negative mass-energy. But, we've never observed it, and it's properties would be pretty weird. We have no reason right now to suspect such a thing actually does or could exist, but maybe we'll be surprised in the future.
This is not correct if by "negative mass-energy" you mean what the OP described:
This is indeed forbidden by physical laws.
https://www.bibliotecapleyades.net/ciencia/negativeenergy/negativeenergy.html
Actually, I recall reading an article in Scientific American many years ago that was about negative energy, and I believe it included a reference to actual observations. I don’t know if it’s at all related to the results from the OP, but I will try to find the article again, and post a link, if it doesn’t present any copyright infringement. Properties I recall include the claims that negative energy would have negative mass, be gravitationally repulsive, and could only be present in a system containing a greater quantity of positive energy. The example I recall was taking an em wave with a trough value close to zero, and then compressing the wave so that the peek would be higher, and the trough would pass below zero.
The article spoke about warp drive and worm holes and all manner of fanciful whimsy.
EDIT TO ADD: Was able to find the link (that article was from 2000!), but couldn’t get it to add on to the end of the post. So, that’s it up at the top.
"Negative energy" is a very misleading description of what that article is talking about. A better description would be "stress-energy that violates the weak energy condition". And it still meets the condition I described in post #4: you can't get something to give off more energy than it has. So it does not qualify as "negative energy" by the definition the OP is using.
Also, Scientific American, despite its name, is not a scientific journal; articles in it are pop science articles for lay people. So they aren't really good sources for PF discussion.
  • · Replies 23 ·
  • · Replies 58 ·
  • · Replies 67 ·
