DaveC426913
2025 Award
- 24,705
- 9,118
No, I've literally used a butterfly flapping. As for the size of the tornado, you can make the boulder as big as you want.BernieM said:Your example is a microscopic event blown up to world sized proportions,
An infinite number of razor sharp peaks exist around your one peak with an equally infinite number of butterflies ready to interact with the boulders; some having boulders balanced on top, others having already fallen, and I believe in the larger picture which way the boulder has fallen/is falling/will fall, would be purely random and evenly distributed.
But you can literally map the campground at the base of the mountain onto the continent. Tornado sweeps through Alabama. Butterfly beats its wings, tornado does not sweep through Alabama.BernieM said:The event or non-event that happened to the camper below is a very localized phenomena and the fact that you personally being one of those campers who experienced a tornado, does not prove a tornado existed or will exist for all other campers below all the other peaks around.
You are describing a classical convergent system. i.e. your assumption is that disturbing another boulder will cause it to fall. i.e. that lots of disturbances reduce the whole system to a lower entropy state. No. In a chaotic system, one boulder falling will just as likely cause another boulder to land on a peak.BernieM said:The net effect of ground vibrations caused by boulders rolling downhill and influencing other boulders precariously perched on other peaks, movement of air currents created by the rolling boulders possibly blowing away nearby butterflies, microgravitational effects by the redistribution of the mass of the boulders as they change position (which if your boulders were perched so precariously could also cause nearby boulders to shift and fall),
What do you mean "larger picture"? All we are demonstrating is that a butterfly flapped its wings and a tornado occurred in Alabama. Roll the process back, butterfly does not flap its wings, no tornado in Alabama.BernieM said:etc, have not been included in your model. Given all these additional interactions, how instrumental is the butterly effect and how much does it really impact the larger picture?
Actual atmospheric phenomonea require you use the right model. Don't use a classical model.BernieM said:In a mathematical model it is easy to include or exclude anything you like and view the results without the influence of things that you don't want in the model. Actual atmospheric phenomena you can't do that.
