Does the Delta Sequence Converge to the Dirac Delta Function?
12 replies · 3K views · last reply
Undoubtedly0
Show that [tex]\delta_n(x) = ne^{-nx} \quad \mathrm{for}\quad x>0[/tex][tex]\qquad = 0 \quad \mathrm{for}\quad x<0[/tex]
satisfies [tex]\lim_{n\longrightarrow\infty}\int_{-\infty}^\infty \delta_n(x)f(x)\mathrm{d}x = f(0)[/tex]
The attempt at a solution
The hint says to replace the upper limit ([itex]\infty[/itex]) with [itex]c/n[/itex], where [itex]c[/itex] is "large but finite", and then use the mean value theorem of integral calculus.
I do not understand how this replacement in the hint is allowable. Since [itex]n\longrightarrow\infty[/itex], [itex]c/n\longrightarrow0[/itex], not [itex]\infty[/itex]. Even if this is okay, how does it aid using the mean value theorem of integral calculus?
voko said:
Are there any restrictions on f(x)?
It is only stated that [itex]f(x)[/itex] is a well-behaved function. It seems that this would be easier to prove if [itex]\lim_{x\longrightarrow\pm\infty}f(x)[/itex] was at least finite, but no such assumption is made.
Then assume the integral of f(x) over the entire real line is finite. Given that, you should be estimate the "left-over" as you restrict integration to c/n.
Why can this be assumed? Not even a function as well-behaved as [itex]f(x)=x^2[/itex] satisfies this.
## e^{x^{100}} ## is also well behaved, but will it be acceptable in this case?
Sure, if [itex]f(x) = e^{x^{100}}[/itex], then I do not know how I would answer the problem. Any suggestions?
As I said, you should select a class of functions that are admissible. Those whose integral over the entire real line is finite obviously fit the bill. Those the product of which with exp(-x) has the same property would work, too.
Evidently, however, the proof can be made for any well-behaved function [itex]f(x)[/itex]. I understand how to prove this for special cases, but I am confused on how to prove this in general.
## \delta_1 = e^{-x} ## so you must have at least ## \int_0^{\infty} f(x)e^{-x} dx < \infty## for any "well-behaved" function.
If there exists a Taylor series expansion of f(x) of the form [tex]f(x)=\sum_{k=0}^\infty f^{(k)}(0)\frac{x^k}{k!}[/tex]
does that imply that ## \int_0^{\infty} f(x)e^{-x} dx < \infty##?
Thanks for your help.
You are asked to show this for n a fixed constant. There is nothing said about "n going to infinity" and no reason to worry about that.
Hi HallsofIvy. I confess I do not understand what you mean. Certainly the following says that n goes to infinity, no?
[tex]\lim_{n\longrightarrow\infty}\int_{-\infty}^\infty \delta_n(x)f(x)\mathrm{d}x[/tex]
