Does the discriminant test apply to this conic?
  • Thread starter Thread starter flyingpig
    Apply Test
21 replies · 4K views · last reply
flyingpig
Let's say I have 3x2 + 3y2 + 3z2 + 8xz - 8xy - 8zy
How can I apply the discirminant test to this 3d surface?
In all of them, I keep getting 64 - 36 > 0
But there are like different kinds of hyperbola in 3d...
i don't want to use traces.
That's not a conic section.
flyingpig said:
Why?
Why do you think it is? Conic sections are curves, not surfaces. You have a quadratic surface. That's not the same as a conic section.
flyingpig,
One thing that should be cleared up is what exactly are you working with.
This isn't an equation, so it's hard to say what you're working with.
If it's really 3x2 + 3y2 + 3z2 + 8xz - 8xy - 8zy = 0, then that is a surface in R3.
If it's w = 3x2 + 3y2 + 3z2 + 8xz - 8xy - 8zy, then the graph would require four dimensions.
Mark44 said:
flyingpig,
It is 3x2 + 3y2 + 3z2 + 8xz - 8xy - 8zy = 0, but isn't it just a conic in 3d...?
As Vela and Dick said, it's not a conic section, which is a curve. Here's a link to an article on Quadric Surfaces, one of which your equation represents.
Your equation represents a sphere, I'm pretty sure, but the xy, yz, and xz terms cause the thing to be tilted on all three axes.
Actually, checking on Wolfram-Alpha, it appears to be an elliptic cone.
You're going to have to convince me of this. The coefficients of all three squared terms are 1) positive and 2) equal, leading me to my assertion that the thing is a sphere. If it were a cone, I would expect the coefficient of one of the squared terms to be negative.
My first instinct was that it should be a sphere as well.
However, there's this odd thing that the equation equals zero...
So I solved the system and found the eigenvalues 11, -1, -1.
This means that we can reduce the system to the form:
11x2 - y2 - z2 = 0​
with an appropriate orthonormal base transformation (read: rotation).
This is not just an elliptic cone, it's a circular cone!
In retrospect I could have guessed, since only elliptic cones would contain (0,0,0). :smile:
flyingpig said:
How could sphere's axis be "tilted"?
It can't! :smile:
It can only be translated.
So I think a quadric of a sphere can actually never have terms like xy, xz, or yz.
But it can have terms like x, y, and z.
Well, it can but since every diameter of a sphere is and "axis", it would still look exactly the same!
Arggghh, damn. The whole login again, lost my post.
I had a long explanation written agreeing with HallsOfIvy.
Also, it's hyperbolic.
See
solve for z and graph of 1 branch
Also, took me forever to find
the whole graph.
In the future, please always post your wolfram links!
Doesn't that make it a variation of "hyperboloid of 1 sheet"?
It is not a hyperboloid and it is not a sphere.
It is a circular cone (which is a degenerate hyperboloid).
Note that (0,0,0) is part of the surface.
How do you check then? Without referring to another reference. My contour plots are rpetty ugly and bad...
The method to classify a quadric surface is that you first bring the equation in the form:
[tex]\boldsymbol x Q \boldsymbol x^T + P \boldsymbol x^T + R = 0[/tex]
I'm following wikipedia's notation here, where Q is a symmetric matrix, P is a column vector, and R is a scalar.
Then you determine the eigenvalues of Q.
Let's say they are [itex]\lambda_1, \lambda_2, \lambda_3[/itex].
The quadric will be a surface described by:
[tex]\lambda_1 x^2 + \lambda_2 y^2 + \lambda_3 z^2 + R' = 0[/tex]
The difference is only a rotation and a translation.
I think R' is a different constant than the original R if you have a non-zero P.
(In your case R' is equal to R because P=0.)
From this you should be able to classify it yourself, or use e.g. wikipedia for a list of the cases.There! I managed it without any references! :smile:
(Uhh, although I did refer to wikipedia. :rolleyes:)
I don't think you're supposed to.
You'd look it up if you need to.
What is doable, is to learn the classification method I described.
