- 24,752
- 795
atyy said:Maybe the calculated entropy is more like an entangelment entropy, in which case it would be a correction to the BH entropy, and not required to take such a special value?
Corichi's review http://arxiv.org/abs/0901.1302 refers to http://arxiv.org/abs/hep-th/0501103 for different views of what's actually being calculated.
I can't comment, hopefully someone else will be able to carry your idea further. However in line with the topic of this thread, the Immirzi,
there is what I regard as a really extraordinary talk by James Ryan here:
http://relativity.phys.lsu.edu/ilqgs/
Simplicity Constraints and the Immirzi Parameter in Discrete Quantum Gravity
It was given 12 April. The audio file is good quality. Here is the PDF
http://relativity.phys.lsu.edu/ilqgs/ryan041211.pdf
Ryan is reporting work done with Bianca Dittrich at AEI.
(He got his PhD at Cambridge with Oriti and then went to Perimeter, where he was Hossenfelder's officemate for a while. Has collaborated with Livine several times IIRC.)
Also I think you may have seen this one, I did not take enough time to understand and could not immediately make much out. But it's also something recent about the Immirzi.
http://arxiv.org/abs/1104.4028
Perturbative quantum gravity with the Immirzi parameter
Dario Benedetti, Simone Speziale
(Submitted on 20 Apr 2011)
"We study perturbative quantum gravity in the first-order tetrad formalism. The lowest order action corresponds to Einstein-Cartan plus a parity-odd term, and is known in the literature as the Holst action. The coupling constant of the parity-odd term can be identified with the Immirzi parameter of loop quantum gravity. We compute the quantum effective action in the one-loop expansion. As in the metric second-order formulation, we find that in the case of pure gravity the theory is on-shell finite, and the running of Newton's constant and the Immirzi parameter is inessential. In the presence of fermions, the situation changes in two fundamental aspects. First, non-renormalizable logarithmic divergences appear, as usual. Second, the Immirzi parameter becomes a priori observable, and we find that it is renormalized by a four-fermion interaction generated by radiative corrections. We compute its beta function and discuss possible implications. The sign of the beta function depends on whether the Immirzi parameter is larger or smaller than one in absolute value, and the values plus or minus one are UV fixed-points (we work in Euclidean signature). Finally, we find that the Holst action is stable with respect to radiative corrections in the case of minimal coupling, up to higher order non-renormalizable interactions."
