Does the sequence ln(n)²/n converge to 0?
34 replies · 6K views · last reply
I'm simply amazed at the apparent impossibility of isolating ##n## in
\big| \frac{ 2 ln(n)}{n}\big| \lt \varepsilon
and the impossibility of Squeezing ##\frac{2 ln (n)}{n}## properly. There is no function that I can think of which does the job.
I do not know if the following proof is rigorous, but I present it still:
\begin{flalign*}
a_n = \frac{ 2 ln(n) }{n} \\
A_n = e^{a_n} = (e^{ln(n)})^{2/n} = (n^{1/n})^2\\
\lim A_n = \lim n^{1/n} \cdot \lim n^{1/n} = 1\\
\lim e^{a_n} = 1 \\
\textrm{As}~e^x~\textrm{is a continuous function, we have} \\
\lim a_n = a_0 \implies \lim e^{a_n} = e^{a_0} = 1 \implies a_0 = 0 \\
\textrm{Thus,} ~~\lim a_n = 0\\
\end{flalign*}
vela said:
This argument doesn't really work. Suppose instead we assume ##n=1## instead of ##n=3##. The rest of the argument would remain unchanged, but it would be wrong to conclude the sequence is decreasing after ##n=1##.
Your assumption is that the sequence isn't decreasing for all ##n > 3##. The contradiction tells you the sequence decreases for some ##n > 3##. That's not the same as saying the sequence decreases for all ##n > 3##.
@Hall you did not respond to this...i would be interested on your view on this...
chwala said:
@fresh_42 ...you had mentioned in my other post that I cannot use L' Hopital's rule...kindly clarify...cheers.
The rule is applicable for differentiable functions. You can conclude with L'Hopital that
[tex] \lim _{x\to\infty} \frac{\ln x^2}{x} = 0.[/tex]
In the discrete case this is also true due to continuity.
You should be careful, though. You claimed something like
[tex] \lim _{x\to a} f(x) = L \Rightarrow (a_n \to a \Rightarrow \lim _n f(a_n) = L).[/tex]
This is true for continuous functions. To be more precise, the function of interest has to be continuous around the point of convergence. In the event ##x\to\infty##, it should be that ##f## is continuous from some point onward.
You state that the rule applies to differentiable functions? This function is not continous at ##x=0##, do we still consider it as a differentiable function?
In my understanding, if a function is not continous then it is not differentiable.
The limit is being taken as [itex]x \to \infty[/itex]; the behaviour of the function at [itex]x = 0[/itex] is of no consequence.
