Does this equation have a name?
  • Level: Undergrad
  • Thread starter gamow99
gamow99
I'm trying to figure out how many times my computer will have to loop through an array. I'm building a logic calculator so it's checking contradictions. If there are four sentences, a b c d, then one has to check the following combinations to see if there is a contradiction
ab
ac
ad
bc
bd
cd
The equation seems to be, let n = the number of sentences:
(n - 1) + (n - 2) + (n - 3)
But that's not a good equation because it does not inform us how many things to add together.
If there are six sentences then the equation would be
(n - 1) + (n - 2) + (n - 3) + (n - 4) + (n - 5)
There has to be a better way to write that equation.
In probability, it looks like it would be written as 4 choose 2, meaning that you have 4 sentences and choose 2 of them. The equation gives the number of unique results (ab is the same as ba). Google "Combination".
Hey, computer scientist here. Cool project you're working on. I stumbled across this pattern while messing around with tabular K-map simplification (boolean logic):
You have 4 variables (but this can be generalized to n variables) and are trying to find the total number of associative expressions such that AB = BA. (Looping through for A AND B as well as B AND A would be inefficient)
This problem is analogous to finding the number of lines between a given number of points (see below). The formula is
\frac{n^2-n}{2}
Send me a PM: I'd like to take a closer look at your logic calculator.
Hand-drawn triangle with vertices labeled A at top, C at bottom left and B at bottom right; sides labeled AC, AB and BC in circles; the text #=3 at upper right.
Hand-drawn diagram of a square with corners labelled A, B, C and D, with all six diagonals and sides drawn as lines between each pair of corners, each line labelled AB, AC, AD, BC, BD and CD, and the text # = 6 below.
*plus sign changed to minus sign as per jz92's post
  • Handwritten sketch of a triangle with vertices labelled A at the top, C at bottom left and B at bottom right, each side labelled with a circled pair: AC, AB and BC. Beside it is the handwritten note #=3.
  • Hand-drawn square with corners labelled A, B, C and D, all six diagonals and sides joined, with each line labelled by its pair: AB, AD, BC, CD, AC and BD, and the note # = 6 at the bottom right.
The general equation for evaluating the number of unique combinations when you select k items from a set of n items is:
\frac{n!}{(n-k)!*k!}
n choose 2 is
\frac{n!}{(n-2)!*2!}
Simplified, it is:
\frac{n^2-n}{2}
Comparing each combination of 2, where there are 4 sentences, comes out to a total of (16-4)/2, or 6 comparisons. This, of course, requires that the loops are set up in a way that you never test the same combination twice.
