Does this solution make sense?
  • Thread starter Thread starter supernova1203
The problem involves calculating the speed of a jet flying from Bangkok to Tokyo, given a distance of 4800 km and a speed reduction of 200 km/h on the return trip. The difference in flight times is stated to be 2 hours. The calculations lead to a quadratic equation, which is solved to find that the speed of the jet from Bangkok to Tokyo is 800 km/h. The solution is confirmed by eliminating the negative speed result, which is not feasible.
supernova1203
The solution is at the bottom you can skip right to it if you like
1. Homework Statement
A jet flew from Tokyo to Bangkok, a distance of 4800 km. On the return trip, the speed was decreased by 200km/h. If the difference in the times of the flights was 2 hours, what was the jet's speed from Bangkok to Tokyo?
2. Homework Equations
Distance=(speed)(time)
Time=Distance/Speed
Speed=Distance/Time
3. The Attempt at a Solution
On sample questions they showed us how to solve a problem like this, i attempted to solve it in a similar manner however as you will see i was unable to
Let x represent speed
D=4800 Speed=? Time =?
Distance Speed Time
A to B 4800 x 4800/x (since time = d/s)
Tokyo
to Bangkok
B to A 4800 (x-200) 4800/(x-200)
Bangkok Since on return
to Tokyo trip speed was
reduced by 200
Time -2
4800/x +4800/(x-200)=-2
Lowest common denominator = x(x-200)
Here we multiply everything by x(x-200)
4800/x*x(x-200)+4800/(x-200)*x(x-200)=-2x(x-200)
Here some of the variable cancel out and the calculations are made and we are left
with the end result which is
4800x-960000+4800x=-2x(x-200)
4800x-960000+4800x=-2x^2+400x (On next step the 2x^2 and the right side is moved to
2x^2-400x+4800x-960000+4800x=0 the left side, hence the change in signs)
2x^2-400x+4800x+4800x-960000=0
Basically at this point my calculations got sketchy because there were several ways of going about this problem at this point, also I believe i had made some errors early in my calculations.
I was able to solve this however i should give credit where credit is due
I would like to thank:
sjb-2812 (For fixing the -2x^2 to what it should be which is 2x^2 without the negative)
Apphysicist
zgozvrm
Solution
D = distance
S=speed
T=time
d=st
t=d/s
s=d/t
let x represent the speed
(x-200) because on the return trip the speed was reduced by 200
Distance Speed Time
A to B
(Tokyo 4800 x 4800/x
to Bangkok)
(Bangkok
to Tokyo)
Total 2
4800/(x-200) - 4800/x = 2
LCD is x(x-200)
4800/(x-200)*x(x-200)-4800/x*x(x-200)=2x(x-200)
the two (x-200) cancel out here as well as the 2 x's cancel out
4800x-4800(x-200)=2x(x-200)
4800x-4800x+960000=2x^2-400x
960000=2x^2-400x
=2x^2-400x-960000
2(x^2-200x-480000)
Standard form-------> =(x^2-200x-480000)
a=1
b=-200
c=-480000
Quadratic equation here
-b+-Sqrt b^2-4ac/2a
-b+sqrt b^2-4ac/2a
-(-200) + sqrt (-200)^2-4(1)(-480000)/2(1)
+200 + sqrt 40000-4(-480000)/2
+200 + sqrt 40000 + 1920000/2
+200 + sqrt 1960000/2
200+1400/2
1600/2
x^1=800
x^2
-b-sqrt b^2 - 4ac/2
200-1400/2
-1200/2
=-600
x^2=-600
Since x^2 does not make sense because its a negative, it is logical to conclude the solution is x^1, which is x=800
Therefore the speed of the jet from Bangkok to Tokyo was 800km/h
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
