Does this vorticity plot make sense?
  • Thread starter Thread starter blink-
    Plot Vorticity
The discussion focuses on analyzing a vorticity plot for lid-driven cavity flow, where the expected negative vorticity aligns with the clockwise flow direction. Participants note that the outer flow does not need to exhibit negative vorticity throughout, as the upper edge's large negative vorticity is anticipated due to the free shear layer. Questions arise regarding the units of measurement and the free stream velocity, which are crucial for interpreting the plot accurately. Additionally, positive vorticity is generated along the wall due to the boundary layer, regardless of the rotation speed of the inner and outer flows. Overall, the behavior of the vorticity field raises questions about its consistency with theoretical expectations.
blink-
I'm trying to plot the vorticity field for lid-driven cavity flow. Because I'm looking at 2D flow, the vorticity is plotted as a scalar field The flow field is clockwise, and I would expect the majority of the resulting vorticity field to be negative (right hand rule). However, it seems as thought it has some weird behavior. What do you think?
http://i.imagebanana.com/img/h3ke22hx/Selection_049.png
Having never studied or even read anything about this flow, I would say it looks reasonable. What do you think is weird about it?
If the outer parts do not rotate quicker than the inner parts, you don't need a negative vorticity in the whole plane. The upper edge is a bit surprising with its large negative vorticity.
The large negative vorticity at the upper part is exactly what I would have expected since it is a free shear layer. Of course I don't know what the magnitude should be, and we don't know what the units are.
What are the units? Also, what is the free stream velocity?
As the flow turns down near the far right edge, positive vorticity is generated along the wall due to the boundary layer that forms on that surface. Positive vorticity would form along the walls regardless of how quickly the outer and inner parts are rotating (as long as they are rotating and generating a flow along the walls). If the flow were rotating faster I would expect the layer of positive vorticity to become thinner and for its magnitude to increase.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
