Optimizing Dolphin Tracking: Calculating the Angle for Dart Gun Accuracy
The discussion focuses on calculating the angle at which a dart gun should be aimed to accurately hit a dolphin swimming at a depth of 2 meters while the scientist is positioned 1 meter above the water. Using Snell's Law, represented by the equation n1 * sin(theta1) = n2 * sin(theta2), the correct angle of incidence was determined to be 32 degrees in water. The miscalculation arose from incorrectly interpreting the angles in the ray diagram, leading to confusion about the straight path of the dart. The final angle from the horizontal for the dart gun should be calculated based on the correct application of the refractive index of water, which is 1.33.
  • Understanding of Snell's Law in optics
  • Basic knowledge of angles and vector representation
  • Familiarity with the concept of refractive index
  • Ability to visualize ray diagrams in physics
  • Study the application of Snell's Law in various mediums
  • Learn about vector addition in physics
  • Research the effects of refraction on projectile motion
  • Explore practical applications of optics in marine biology
Physicists, marine biologists, and anyone involved in the design of tracking devices for wildlife research will benefit from this discussion.
Seneka
A scientist investigating the movements of dolphins in the Mediterranean uses a dart gun to shoot small, harmless tracking devices onto the fins of dolphins. When standing on deck, her hand is 1m above the water, and looking along the dart gun she is holding at an angle of 45∘, she sees a dolphin. Using sonar she has found that the dolphin is swimming at a depth of 2m. We know that the refractive index for water is 1.33. At what angle from the horizontal should she point the dart gun to hit the dolphin?
n1sintheta1=n2sintheta2
Answer:
I worked out the angle in the water to be 32 degrees using the equation above and extended that line from the dolphin to the refracted ray above the water to the scientists hand. I knew that this would make an angle of 180 degrees so I subtracted 32 and 90 from 180 to give me 58 degrees as the answer. This is wrong but I don't understand why. Why do you treat the the two rays as vectors and why do you add them? What is wrong with my working out?
That sequence does not produce a straight line, it merely reproduces the bent line in the ray diagram.
The task is to find the angle of the straight path the dart will take.
Likes   Endorsed by: Seneka
Cool, thanks
This problem seems very unrealistic and completely ignores whether or not that dart would actually be able to reach the dolphin after impacting on the water surface ...
