Domain of f(x) = sqrt(1-sin(x)): Understanding and Calculating
In summary, the domain of f(x) is all real numbers except for every increment of 90 degrees. The domain of f'(x) is all real numbers. To find the domain, we need to find the values of x that make sin(x) less than 1. The graph of sin(x) can be used to understand this.
unf0r5ak3n
36
let f(x) = sqrt(1-sin(x))
What is the domain of f?
What is the domain of f'(x)?
I understand that the domain of f is all real numbers not including every increment of 90 degrees, but I am not sure how to state that.
I also found that f'(x) = (1/2 -sin(x))(-cos(x)) I am not sure if that's correct though
A point is not in the domain if it does not have a function value. The only possible situation that [tex] f(x)=\sqrt{1-sin(x)} [/tex] does not exist, is when you take the root of a negative number. So you will have to search for what x we have that 1-sin(x)<0.
go on google and type
wolfrom alpha
look at the graphs and try understand
Micromass is spot on here, for what values of x satisfy [tex]\sin x\leqslant 1[/tex]? Do you know the graph of [tex]\sin x[/tex]?
so the domain is all real numbers except when sin(x)<1?
Yes! But can you say explicitly when sin(x)<1?
No that's not what we're saying the domain if all numbers which satisfy sin(x)<1, not the other way around.
thats where i got lost
1. What is the domain of f(x) = sqrt(1-sin(x))?
The domain of a function is the set of all possible input values for which the function is defined. In this case, the square root function is defined for all non-negative numbers. Since the expression inside the square root, 1-sin(x), can never be negative (sin(x) is always between -1 and 1), the domain of f(x) = sqrt(1-sin(x)) is all real numbers.
2. How do you calculate the domain of a function?
To calculate the domain of a function, you need to identify any restrictions on the input values. These restrictions can come from the type of function (e.g. square root function cannot have a negative input), the given expression (e.g. division by zero is undefined), or any other conditions specified. Once these restrictions are identified, the domain is the set of all input values that satisfy these restrictions.
3. Can the domain of a function change?
Yes, the domain of a function can change depending on the given expression or any restrictions imposed on the input values. For example, if a function has a denominator with a variable in it, the domain will change if that variable is restricted to a certain range. Also, if a function is composed of different functions, the domain may change based on the domains of the individual functions.
4. What happens if the domain of a function is not specified?
If the domain of a function is not specified, it is assumed to be all real numbers. However, in some cases, the domain may need to be restricted to avoid undefined values or to ensure the function is well-defined. It is important to always consider any restrictions on the input values when working with functions.
5. How can understanding the domain of a function help with problem solving?
Understanding the domain of a function is essential in problem solving as it helps to identify any potential errors or restrictions in the given expression. It also allows you to determine the range of possible output values, which can be helpful in finding the maximum or minimum values of a function. Additionally, knowing the domain of a function can help in determining the behavior and graph of the function.
