Doppler Effect Problem (Very Confusing)
The discussion revolves around a confusing Doppler Effect problem presented in a Grade 11 board exam, which lacks sufficient information for a clear solution. Teachers in the group express concern that the problem's parameters lead to unrealistic calculations, particularly regarding the speed of dolphins needed to achieve a specified frequency shift. There is disagreement on whether the source is moving toward or away from the observer, with some suggesting that the question's ambiguity could mislead students. The consensus is that the question is fundamentally flawed, as it does not provide necessary details about the observer or the natural frequency. Overall, the teachers seek clarity and validation on the problem's logic and solution.
affank414
A pod (group) of dolphins produces sound at the speed of 2050 m/s in cold water at a frequency of 100 kHz. If the pod produces sound at a frequency of 150 kHz, then calculate the velocity of the
pod and the wavelength of the sound.
(Note: The speed of sound in air is 340 m/s).
Doppler Effect 2nd case "When observer moving away from source".
P.S. Don't know how to write equation here.
Kindly don't delete the post again, I am a teacher.
The question above mentioned came in Board Exams 2 years ago in our Country. We the group of teachers tried to solve but we found that the problems misses the required information to be solved.
The data still seems to be the case of Doppler's Effect in which source is moving and observer is stationary but still the question lacks the data.
I need review from Senior members on this question. If we're taking this question wrong then let us know the possible logic + solution. Or if the question is contradictory in real then kindly record your comments Thank You.
Kindly don't delete the post again, I am a teacher and discussing this question regarding my students. Or let me know the best place to post this. Thank You.
Welcome to the PF. :smile:
It seems like there is enough information there to solve it, as long as you assume that the upshift in frequency is due to the dolphins swimming toward a stationary observer. However, it does seem like that amount of upshift is unreasonable (unless the dolphins are VERY fast). Can you do that calculation for us to show how fast the dolphins would need to be swimming toward a stationary observer to cause the 100kHz --> 150kHz upshift?
Look in the guidelines (item 7). Or copy in (e.g. wikipedia) pictures:
##\qquad##
242865
:smile:
Do you have a link or an exact rendering of the problem statement ?
##\qquad##
Likes affank414, nasu and berkeman
Thank You
It seems there is enough information there to solve it,
How? Do we have any information regarding Observer?
Yup still If I solve this question as per "Source of Sound moving towards stationary observer", it comes out to be 683 m/s... Which is unrealistic
Another thing the solution I received from the Board (who had given this question in exam), they applied concept of "Source of Sound Moving Away from Observer"... I mean HOW?
I Asked them that how can we apply this concept but couldn't receive proper reply...
And they had given this question in board exam for class 11 level... 😢
Likes berkeman
##\qquad## View attachment 242865
Thanks a lot...
##\qquad##
Sorry, did you mean exact image from the Question Paper itself?
For a speed of sound in water of about ##2,000 m/s## the Doppler shift will be small for the sort of speeds that dolphins can swin (maximum ##10 m/s##, say). There is no way to get a Doppler shift of 50%.
There's clearly something wrong with the question.
Thanks a lot for your feedback...
For instance if we assume these unrealistic values, does this question still give any information about Observer? Also does it still looks like a problem related to Doppler Effect?
If an observer is not mentioned, then I would assume it is at rest in the water. What else could it be except a Doppler shift? If you changed ##150kHz## to ##105kHz## that might make a difference.
And how can we say that source moving towards or away from observer?
That depends how you interpret the question. The question does not make clear what is the natural frequency and the observed frequency. It could be either way round.
It was given in Grade 11 Physics Exam... If we teachers went into detailed discussion then what about students who were giving exams... They had to suffer a lot in exam... 😢
28K
