Doppler effect with moving observer and source: ambulance speed
8 replies · 3K views · last reply
GravityInTheX
As you drive at a speed of 15.0 m/s an ambulance approaches you from behind with its siren blaring at a frequency of 1022 Hz. After the ambulance has passed you the signal is now 981 Hz. If both you and the ambulance travel at a constant speed how fast was the ambulance traveling?
A. 16.0 m/s
B. 18.0 m/s
C. 20.0 m/s
D. 22.0 m/s
E. 24.0 m/s
f0=fs(1/(1+vs/v))
I figured I could use the ambulance's speed relative to the car, so I used the above equation for when a source is moving away from a stationary observer. I plugged in all the variables an solved for vs. I ended up getting vs being equal to 14.33. I then assumed since the speed was calculated with the car having a speed of 0 m/s, I simply added the speed of the car. That got me 29.33 m/s, which doesn't happen to be an answer choice. What am I doing wrong? Thank you so much!
Doppler effect of sound does not depend on the relative velocities alone, you cannot find the relative velocity without taking into account that you move relative to the air.
You can still use this equation, but you have to apply it first to the ambulance (relative to the air) and then to you (relative to their air).
isn't the original equation fo=fs(1+- vo/v)/(1+-vs/v)
That's both steps (ambulance and our car) combined, yes.
22m/s is correct.
