Dot and Cross Products (of Gradients)
  • Thread starter Thread starter jeff1evesque
    Cross Dot
The discussion centers on the mathematical identity involving gradients, specifically the equivalence of the expressions ∇ · (∇ × A) and 0 for any vector field A. Participants confirm that these expressions are indeed identical, as the divergence of the curl of a vector field is always zero, a result derived from vector calculus identities. The confusion arises from the misconception that ∇ · ∇ is the Laplacian operator, which requires a scalar function to operate on, not a vector field. The conclusion emphasizes that ∇ · (∇ × A) = 0 due to the properties of vector calculus.
  • Understanding of vector calculus, specifically divergence and curl operations.
  • Familiarity with the Laplacian operator (∇²) and its application to scalar fields.
  • Knowledge of Clairaut's theorem regarding mixed partial derivatives.
  • Basic proficiency in manipulating vector fields and their derivatives.
  • Study the properties of vector calculus identities, focusing on divergence and curl relationships.
  • Learn about the application of the Laplacian operator in various contexts, particularly in physics.
  • Explore Clairaut's theorem and its implications in vector calculus.
  • Practice solving problems involving the divergence of curl and other vector operations.
Mathematicians, physicists, engineering students, and anyone interested in advanced vector calculus concepts and their applications in fields such as fluid dynamics and electromagnetism.
jeff1evesque
Statement:
I was wondering if the following are identical,
\nabla \bullet \nabla \times \vec{A} = \nabla \bullet (\nabla \times \vec{A}) ? (#1)
Also, more importantly I was wondering if someone could explain to me why the following is zero for any vector,
\nabla \bullet \nabla \times \vec{A} = 0?
Reasoning:
If we look at \nabla \bullet \nabla \times \vec{A}, Isn't \nabla \bullet \nabla the laplacian, or \nabla^{2}? Is that the reason we cannot perform the operation in equation (#1) above- the laplacian is a function that needs a vector field to be operated on, and there is none. So \nabla \bullet \nabla = 0.Thanks, a lot,JL
jeff1evesque said:
Statement:
Reasoning:
Thanks, a lot,
JL
Yeah they're identical. Check out http://en.wikipedia.org/wiki/Triple_product" on what's called the "triple product."
\nabla \bullet \nabla \times \vec{A} = 0 = div(curl(A))
I mean if you think of it in terms of geometrical vectors, then if we're looking at the divergence of the amount of A which is contained it sort of intuitively seems like it should be zero.
If it's too hard to visualize then just work it out. Assume A is a vector function and take the curl of A then the divergence of the curl of A and by Clairaut's theorem you should see that it all cancels out.
Secondly (\nabla \bullet \nabla) \times \vec{A} makes no sense you cannot take the cross product of a scalar operator (which the laplacian is).
Finally the laplacian doesn't equal zero. It's a linear operator, it doesn't equal anything be itself. In fact it really doesn't have any meaning by itself if it's not being applied to a function in euclidean space.
It's more complicated then that. Work it out and you'll see the derivatives canceling.
I tried, for example I let \vec{H} = 2xy\hat{x} + x^2y^2z^2\hat{y} + x^3y^3z^3\hat{y}.
When I take the curl,
\nabla \times \vec{H} = [3x^3y^2z^3 - 2x^{2}y^{2}z]\hat{x} + [3x^{2}y^{3}z^{3} - 0]\hat{y} + [2xy^{2}z^{2} - 2x]\hat{z} and let that whole thing equal \alpha
So now when I take the divergence,
\nabla \bullet \alpha = (9x^{2}y^{2}z^{3} - 4xy^{2}z) + 9(x^{2}y^{2}z^{3}) + (4xy^{2}z) = 18(x^{2}y^{2}z^{3}) \neq 0
It seems like it almost worked out, the second term above needed a sign change, but I've reviewed the calculation, and it doesn't seem that I've made a mistake.
...makes no sense you cannot take the cross product of a scalar operator (which the laplacian is).
That was along the lines I was thinking, the laplacian requires a vector to be operated on, and it doesn't have one.
\nabla \times \vec{H} = [3x^3y^2z^3 - 2x^{2}y^{2}z]\hat{z} + [3x^{2}y^{3}z^{3} - 0]\hat{y} + [2xy^{2}z^{2} - 2x]\hat{z} and let that whole thing equal \alpha
I think your second term (the y-hat term) is missing a minus sign here.
Hi jeff1evesque! :smile:
(have a del: ∇ and use \cdot, not \bullet:wink:)
Reasoning:
You're very confused. :redface:
Learn the following:
div curl = curl grad = 0
div(curlA) = ∇.(∇xA) = 0
curl(gradφ) = ∇x(∇φ) = 0
div(gradφ) = ∇2φ = Laplacian.
∇.(∇xA) is zero for the same reason that B.(BxA) is zero. :wink:
The y-hat consists of the following,
[\frac{\partial}{\partial x}(x^{3}y^{3}z^{3}) - \frac{\partial}{\partial z}(2xy)]\hat{y} = [3x^{2}y^{3}z^{3} - 0]\hat{y}
Am I incorrect?
Am I incorrect?
That is incorrect; it is the negative of that.
Thanks, I totally forgot (the notation is similar to taking determinants).
  • · Replies 0 ·
