sqljunkey
- 181
- 8
Using the principle of least action can you figure out which path the photon took, or which slit it went thru given some initial condition. Or is this not possible and why.
The discussion centers on the application of the principle of least action in understanding the double-slit experiment and the behavior of photons. It is established that photons do not take a single path; rather, they traverse all possible paths, as explained by the path integral formulation of quantum mechanics. Richard Feynman's insights highlight that assuming a photon travels through one slit contradicts experimental results. The principle of least action applies in the classical limit, but quantum mechanics reveals that photons exhibit wave-particle duality, complicating the notion of a definitive trajectory.
PREREQUISITESPhysicists, students of quantum mechanics, and anyone interested in the foundational principles of quantum theory and the behavior of light in experimental settings.
You also have to know the times at which the photon is at these positions. It’s not enough to say “there’s a dot on the film here”, you also have to be able to say when that dot appeared. You can do that for the detection event but not the emission event.sqljunkey said:if I know the initial position and the final position of the photon...
Let's say you shine a beam of light trough long cylinder of glass. Let's say that cylinder is so long that the path around cylinder trough the air would take less time for light to travel. Would you expect that light will go around cylinder just because this path takes less time to travel?sqljunkey said:But assuming this principle, there could be only one right path. if the photon had to go through both slits that means one of these trajectories was longer than the other one and would take more time and more action. and we know light takes the path of least action and least time.
Idea that quantum particles are somehow switching between particle like behavior and wave like behavior is simply flawed. If this idea is hunting you, you can try to adopt Bohmian interpretation to get rid of it.sqljunkey said:But it's certainly an alternative idea to a shy particle that quickly turns into a distribution wave-like glob when people aren't looking at it and then back into a particle again when people are looking.
sqljunkey said:... And it's either going to be one of these holes, because I have to take the minima of the action.
Correct me if I'm wrong. :3
The quantum mechanical explanation for the double-slit experiment isn’t anything like that.sqljunkey said:But it's certainly an alternative idea to a shy particle that quickly turns into a distribution wave-like glob when people aren't looking at it and then back into a particle again when people are looking.
sqljunkey said:I don't know.
But it's certainly an alternative idea ...
QED tells you that the idea of a "path of a photon" doesn't make sense. That's why the action principle is applied to fields rather than to "trajectories" in the evaluation of QFT path integrals: It's derived from applying the saddle-point approximation to the path integral, which provides a formal expansion in powers of ##\hbar##, i.e., is a systematic expansion around the "classical field-theory limit", i.e., in this case Maxwell classical electrodynamics.sqljunkey said:Using the principle of least action can you figure out which path the photon took, or which slit it went thru given some initial condition. Or is this not possible and why.
