Dp/dt in the relativistic domain
  • Context: Graduate
  • Thread starter Thread starter Repetit
    Domain Relativistic
The equation \(\overrightarrow{F}=\frac{d\overrightarrow{p}}{dt}\) is valid in the relativistic domain, provided that the time-dependence of mass is fully accounted for. The discussion emphasizes the use of the product rule for momentum, \(\frac{dp}{dt} = \frac{d}{dt} (m_r v) = \frac{dm_r}{dt} v + m_r \frac{dv}{dt}\), or expressing momentum in terms of invariant mass, \(\frac{dp}{dt} = \frac{d}{dt} \left( \frac{m_0 v}{\sqrt{1 - v^2 / c^2}} \right)\). It is noted that while \(\frac{dp}{dt}\) can define "force" in both special relativity (SR) and Newtonian physics, the term "force" is best avoided in the context of SR to prevent confusion.
  • Understanding of relativistic momentum and invariant mass
  • Familiarity with Newton's second law of motion
  • Knowledge of calculus, specifically the product rule
  • Basic principles of special relativity (SR)
  • Study the implications of relativistic mass and its effects on momentum
  • Learn about alternative definitions of force in special relativity
  • Explore the mathematical derivation of relativistic momentum
  • Investigate the relationship between force and acceleration in relativistic contexts
Physicists, students of physics, and anyone interested in the applications of Newtonian mechanics in the relativistic domain.
Repetit
Just a quick question which came to my mind when reading a historical article on Newtons second law. Is \overrightarrow{F}=\frac{d\overrightarrow{p}}{dt} correct in the relativistic domain because the mass is not necessarily constant?
It still works, so long as you take into account the time-dependence completely. Either use the product rule:
\frac{dp}{dt} = \frac {d}{dt} (m_r v) = \frac{dm_r}{dt} v + m_r \frac{dv}{dt}
or write it in terms of invariant mass:
\frac{dp}{dt} = \frac {d}{dt} \left( \frac {m_0 v} {\sqrt {1 - v^2 / c^2} } \right) = m_0 \frac {d}{dt} \left( \frac {v} {\sqrt {1 - v^2 / c^2} } \right)
F=dp/dt can be taken as one definition of "force" in either SR or Newtonian physics. However there are other possible, equally reasonable, definitions of "force" in SR. It is best to stop using the word "force" in SR. If you mean
dp/dt, just say dp/dt.
  • · Replies 25 ·
  • · Replies 40 ·
  • · Replies 38 ·
  • · Replies 36 ·
  • · Replies 47 ·
