Dummy index and renaming if not a tensor
  • Thread starter Thread starter binbagsss
    Index Tensor
The discussion centers on the rules for renaming dummy indices in tensor calculus, particularly concerning the Levi-Civita symbol. It is clarified that there is no restriction on renaming dummy indices as long as they are repeated summation indices, regardless of whether the object is a tensor. The conversation also addresses the confusion around variations and how to properly handle indices when taking variations of actions. A specific example illustrates how to manipulate indices to facilitate the calculation of variations. The participants emphasize the importance of clarity in the original problem statement for effective assistance.
binbagsss
see below
see below
Apologies it's been a little while since I've done this, but I believe the rule is, that if the object is not a tensor you can not rename the dummy index?
For example, i have the action
##\int d^3 x \epsilon^{uvp} A_u \partial v A_p ## and I want to write this in terms of the ##i## and ##0## components (so that I can take ##\frac{\delta S}{\delta A_0}## and so later on, I imagine, once I've intergreated by parts etc, it will become handy to rename the dummy indicies, but this can not be done for the levi-civita symbol...is this correct?
many thanks
binbagsss said:
[...] but I believe the rule is, that if the object is not a tensor you can not rename the dummy index?
I don't think there's any such rule. If an index is a (repeated) dummy summation index, you can rename it.
##\int d^3 x \epsilon^{uvp} A_u \partial v A_p ## and I want to write this in terms of the ##i## and ##0## components (so that I can take ##\frac{\delta S}{\delta A_0}## and so later on,[...]
You might not need to do that. E.g., $$\epsilon^{\mu\nu\rho} \frac{\delta A_\rho}{\delta A_0} ~=~ \epsilon^{\mu\nu\rho} \delta^0_\rho ~=~ \epsilon^{\mu\nu 0} $$
Sorry , well I meant like if you have ##A^a B_a A_b B^b - A^aA_pB_aB^p## you can rename ##p## in the second term to ##b##say. (The reason I want to rename is to cancel the variation##\delta A_{\mu}##but in the two terms I have got they have different indices in this variation).. (but I will also read through what you said in a bit)
okay that looks simple enough, so also using the chain rule on the variation ##\frac{\delta S}{\delta A_0}= \frac{\delta S}{\delta A_{\rho}}. \frac{\delta A_\rho}{\delta A_0}##?
Actually in this case, it was a variation wrt ##A_{i}## and the final answer is a expression involving ##\epsilon^{ij}## with only two-indices and not three, I'm really confused how one managed to go from an expression involving a three index levi-civta tensor to an expression involving only two.
Many thanks
Well, I can't be sure without seeing the full original context. Maybe because one of ##\epsilon## indices is ##0##?
(This is why we normally insist on a more complete "homework statement". The one in your opening post is not adequate for helping you properly.)
okay but in answer to the original question , say i have ##\epsilon_{abc}A^bB^{ac} ## can i rename say ## b \to d## as:##\epsilon_{adc}A^dB^{ac}##?, for the levi-civita symbol, as it's not a tensor, was my initial question
Yes. The summation convention doesn't care whether it's a tensor or a goose. :oldbiggrin:
Hi okay, apologies I am now stuck on this (this wasn't the origianl question nor intention of my post and hence why I did not state the full problem at the start, but I think it makes more sense to post it here since we went that way anyway..)So i have ## \epsilon^{uvp} a_u \partial_v a_p ## (as the integrand under a 3d integral) and I wantt o find the variation w.r.t ##a_i##. where ##i = 1,2 ## running only over the spatial indicies.
So, so far I have
## \epsilon^{nup}(a_u + \delta_u)\partial_v(a_p+\delta a_p) ##and so to order ##\delta a## after integrating the by parts the first term to order :
##\epsilon^{nup} (- \partial_v a_u \delta_p + \partial_v a_p \delta a_u ##.
And now this is where my confusion is as I can't factorise out ##\delta a ## to get ##\delta S / \delta a^c ## since both terms have different indicies on delta a .
So ## \delta S / \delta a^i= \delta S/ \delta a^ c . \delta c/ \delta a^i ##, however , where ##c## runs over all 3 indices, and ##i## only the spatial ones
but I'm stuck because i don't have ## \delta S/ \delta a^ c ## to even apply the chain rule since i can't factorise out ##a## as said above
thanks
Where did the "n" index on ##\epsilon## come from? A typo? I'm guessing what you meant was: $$\epsilon^{uvp}(a_u + \delta_u)\partial_v(a_p+\delta a_p) ~~~?$$
and so to order ##\delta a## after integrating the by parts the first term to order : ##\epsilon^{nup} (- \partial_v a_u \delta_p + \partial_v a_p \delta a_u ##.
And here there seem to be more typos? I guess you meant $$\epsilon^{uvp} (- \partial_v a_u \delta a_p + \partial_v a_p \delta a_u) ~~~~~?$$
OK. In baby steps, here's what to do. First split it into 2 pieces:
$$\epsilon^{uvp} \partial_v a_p \delta a_u ~-~ \epsilon^{uvp}\partial_v a_u \delta a_p $$
Now rename the indices in one of the terms, so that ##\delta a_p## appears in both terms. (I'll choose the 1st term and interchange ##u \leftrightarrow p##).
$$\epsilon^{pvu} \partial_v a_u \delta a_p ~-~ \epsilon^{uvp}\partial_v a_u \delta a_p $$
Now remember that you can interchange any 2 indices on the ##\epsilon## provided you also change the sign. So the above can become
$$-\epsilon^{uvp} \partial_v a_u \delta a_p ~-~ \epsilon^{uvp}\partial_v a_u \delta a_p $$
which is just $$-2 \epsilon^{uvp} \partial_v a_u \delta a_p ~~.$$ Can you continue from there?
Likes binbagsss
  • · Replies 22 ·
