Durometer for measuring hardness of soft surfaces
  • Thread starter Thread starter icapture
    Meter Type
4 replies · 1K views · last reply
icapture
I am making a tool for my workshop and I need a meter that I can press onto certain soft surfaces to measure their internal pressure. Obviously I will have to calibrate the meter for my specific purposes but I want to buy some and start playing around with my idea.
Basically I need something that has a needle that gets pushed in with a certain amount of force and gives either a mechanical dialed readout or an electronic readout.
I know you guys can help me out!
Sounds like you need a "durometer" hardness tester.
I would put it on a scale, you will know the force.
And: Force / Area = Pressure. (lbs. /square inch)
Measure and calculate the area.
A durometer produces a dimensionless quantity I believe, not a unit of pressure.
There are some important tips on using a durometer on tires or other surfaces:
http://www.longacreracing.com/technical-articles.aspx?item=8167
What range of internal pressures does the meter need to cover?
