How Do You Calculate Elevator Cable Tension for Maximum Acceleration?
The discussion focuses on calculating the elevator cable tension required for a maximum acceleration of 0.068 m/s² for an elevator weighing 4850 kg. The minimum force needed to support the elevator must account for gravitational force, calculated as 47530 N, while the maximum force combines gravitational force and the force required for acceleration, resulting in a net force of 47200 N. The correct interpretation of the forces involved, particularly distinguishing between tension and gravitational forces, is emphasized as critical for accurate calculations.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of gravitational force calculations
  • Familiarity with force vector components
  • Basic principles of elevator mechanics
  • Study the calculation of gravitational force in different contexts
  • Learn about net force and resultant force in physics
  • Explore tension in cables and its applications in mechanical systems
  • Investigate elevator design principles and safety factors
Engineers, physics students, and professionals involved in elevator design and mechanical systems will benefit from this discussion, particularly those focused on force calculations and safety in engineering applications.
yandereni
An elevator(4850kg) is to be designed so that the maximum acceleration is 0.068m/s2. What are the minumum and maximum forces the motor must exert on the supporting cable?
2. Homework Equations
Force = mass(acceleration)
Forcevertical = Ftens + Fgrav
Force = 4850kg(0.068m/s2)
= 329.8N
Forcevertical = 329.8N - 47530N
= -47200N
I'm not so sure about both answers but i think the first solution is kinda right?
thanks in Advance!
Not quite. Think about what is happening. It also has to account for the force of gravity. So the minimum amount of force needed would be to support the force of gravity, and the maximum would be to not only support the force of gravity, but to accelerate the elevator upward at 0.068m/s2. So How would you express those forces with mathematics?
Please define what Forcevertical represents.
Which of the forces in the first equation corresponds to "Force" in this equation?
Forcevertical means forces on the y-axis
Ftens is the one that corresponds to "Force"
No, there are two applied forces (plural) on the y axis, and you have those on the right hand side of the equation. Forcevertical is one force. The word I'm looking for is 'net' force, or 'resultant' force.
Then that's where you are wrong. In the standard equation F=ma, what does F represent? Yes, I know it's a force, but exactly what force?
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 33 ·
