Earth Geodesics - Rhumb Line vs Great Circle
The discussion revolves around the comparison of rhumb lines and great circles in the context of navigating from an object at altitude (A) to a point on the Earth's surface (B). Participants explore the implications of these paths when represented in latitude, longitude, and altitude (LLA) coordinates, considering both theoretical and practical aspects of geodesics and navigation.
  • One participant questions whether a rhumb line or a great circle would more accurately represent the Cartesian vector from A to B in LLA terms.
  • Another participant seeks clarification on the term "rhumb line," suggesting it may be confused with "plumb line." They provide a definition of rhumb lines as paths that cut all meridians at the same angle.
  • A different participant proposes that if movement through the Earth is allowed, the vector should simply follow the straight line connecting A and B.
  • One participant notes that while treating the Earth as a sphere is a good approximation for navigation, only certain rhumb lines are geodesics, specifically the equatorial and polar ones.
  • Another participant concludes that the projection from A to B results in a great circle, asserting that following a rhumb line would lead to deviations from the intended path.
Participants express differing views on the nature of the paths (rhumb line vs. great circle) and their implications for navigation. There is no consensus on the best representation of the vector, as some participants support the great circle while others discuss the conditions under which rhumb lines may be applicable.
Participants reference various mathematical and navigational concepts, but there are unresolved assumptions regarding the movement through the Earth and the specific conditions under which each path type is considered appropriate.
GreenLRan
I have an object (A) at some altitude above the Earth ellipsoid, and a point (B) on the surface of the Earth.
Since you're not confined to the surface of the Earth as you travel from A (at altitude), to B, I'm getting confused.
If I were to create a (Cartesian) vector pointing from object A in the air, to point B on the ground,
would a rhumb line, or a great circle be a more accurate representation of the vector if I were to put the discretized values of the vector in terms LLA (latitude, longitude, and altitude)?
Maybe a better way to ask is: What is the LLA projection of the Cartesian vector pointing from A to B? And would that projection be better represented as a rhumb line, a great circle, or some other calculation?
Thanks
I'm sorry you are not finding help at the moment. Is there any additional information you can share with us?
Thanks
By "rhumb line" do you mean "plumb line"? I've never heard this term.
A 'rhumb line' is a term of art used by navigators to describe a path which cuts all meridians of longitude at the same angle.
http://en.wikipedia.org/wiki/Rhumb_line
A curve which does this is also known as a 'loxodrome'.
In that case, I have to ask are we allowed to move through the Earth? If so...the vector should just be directed along the straight line connecting point A and B. I don't see why not .
For navigation across the Earth, treating it as a sphere is a good approximation. The Earth's flattening is about 1/300, and an airliner typically travels at a relative altitude of 1/600. Mt. Everest is about 1/720 above sea level, the Mariana Trench is about 1/580 below sea level, and the Everest-Mariana difference is about 1/320.
As to geodesic vs. rhumb line, only some rhumb lines are geodesics: the equatorial and polar ones. That's because geodesics are great circles, and all of them have variable bearing except for the equatorial and polar ones.
Interested in the math?
I believe the projection ends up being a great circle, this makes sense to me now. If you're following a rhumb line, you're constantly keeping a fixed azimuth with respect to North (a longitude line), in reality that works the vector off target. I verified by converting from LLA coordinates to ECEF, then making discrete points (X,Y,Z) along a line traveling from A to B. Once I converted the ECEF line back to LLA, it did indeed produce the same results you would get from a great circle.
Thanks for the help guys.
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 44 ·
25K
