Effective Material for Concealing Heat Sources from Infrared Detection
  • Thread starter Thread starter *_DiGi_*
    Infrared
Effective materials for concealing heat sources from infrared detection include heat insulating materials with a sufficient R-value. The discussion highlights that while these materials can shield infrared signatures, they also trap heat, which is crucial for applications like home heating. The example provided involves covering lamps with a combined output of 3000 watts (fifty 60-watt bulbs) to prevent infrared detection. The thickness of the material is a key factor in its effectiveness.
  • Understanding of R-value in insulation materials
  • Knowledge of infrared detection principles
  • Familiarity with heat transfer concepts
  • Experience with thermal insulation materials
  • Research effective heat insulating materials with high R-values
  • Explore infrared detection technologies and their limitations
  • Investigate thermal management techniques for heat sources
  • Learn about the impact of material thickness on thermal insulation
Engineers, architects, and anyone involved in thermal management or seeking to optimize heat source concealment from infrared detection.
*_DiGi_*
Is there a material that can effectively make a strong heat source undetectable by infrared, by covering it (the heat source)? A random question, I know - just curious.
Computer science news on Phys.org
How hot are we talking about? How thick can the material be?
Any heat insulating material of sufficient R value will.
It should be noted that any material that shields the infrared appearence of the heat source would also trap the heat. Something to bear in mind if the purpose of the heat source is to heat your house, or if overheating is a concern.
Not extremely hot. I'm not exactly sure what to compare it to for an example...hmm, maybe say you had like fifty 60 watt bulbs in a particular room in your house - in lamps that were placed on the floor. What could you cover those lamps with to make the heat undetectable by infrared?
Thanks for the reply btw.
  • · Replies 16 ·
