Time to fill Tank A with two pumps working simultaneously and against each other
  • Thread starter Thread starter Girn261
    Pumps
6 replies · 2K views
Girn261
A fuel oil supply system consists of two tanks (Tank A and Tank B) and two transfer pumps (Pump A and Pump B) to supply a Bunker C fuel oil to a heating boiler.
Pump A can fill up a Tank A from the minimum level in 15 hours and 20 minutes
Pump B can fill up a Tank B from the minimum level in 17 hours and 30 minutes
Calculate the time to fill up Tank A from the minimum level under the following conditions.
a) both pumps are used simultaneously
b) pump A is used to fill up Tank A while Pump B is transferring fuel out from Tank A to Tank B
for part a) I converted the hours to minutes for both pumps, I assume both tanks to be same size. Pump A = 920mins to fill tank & 1050 mins for pump B. Then I did (1/920+1/1050)x(t)=1 to find t which was 490 mins. But for part B any tips? I'm having a brain fart.
haruspex said:
Consider what the change is over one minute.
Okay I am kinda lost haha. But I did this (1/1050-1/920)=1/x and for x I got 7430 mins. Is that right?
rude man said:
Are the two tanks the same volume? Or are the two pumps of equal capacity? Neither? If neither seems like not enough info given.
thats the exact question, so I think you're suppose to assume the tanks are same volume, while the pumps are different capacity
Yes.
Well, I think it's exactly badly phrased, :smile: but OK you have to assume something, might as well be equal-size tanks..
