Eigenstates of the Klein Gordon Field Operator
  • Context: Graduate
  • Thread starter Thread starter Jonathan Apps
The discussion revolves around the eigenstates of the Klein-Gordon field operator in quantum field theory, specifically focusing on real, spin-0 fields. Participants explore the nature of these eigenstates, their relation to particle number states, and the mathematical framework involved in their characterization.
  • One participant questions what the eigenstates of the field operator for a real, spin-0 field are, noting that states of definite particle number are not eigenstates since their expectation value of the field is zero.
  • Another participant suggests starting with the simpler case of a 1D harmonic oscillator to understand the eigenstates of the operator ##a + a^\dagger##.
  • A participant claims to have identified the eigenstates of the operator ##a## as Poisson distributed coherent states, while asserting that ##a^\dagger## does not have eigenstates in the space of positive integer particle number.
  • Discussion includes a derivation of the eigenstates of the field operator in the Schrödinger picture, relating it to the normal mode expansion and the reality constraint that couples modes ##\vec{k}## and ##-\vec{k}##.
  • Another participant mentions that the referenced derivation relies on discrete commutation relations, suggesting a box-like regularization approach.
  • One participant shares their background in effective action for fields on finite spaces, expressing interest in the discrete aspects of the discussion.
  • Another participant elaborates on the relationship between the free field and the 1D harmonic oscillator, introducing new variables to simplify the coupling between modes and discussing the implications for the field operator.
  • There is a humorous exchange about the universe having a "brick wall" and "stacked turtles," indicating a light-hearted tone amidst the technical discussion.
  • A later post humorously questions whether the turtles are Neumann or Dirichlet, adding to the playful nature of the conversation.
Participants express various viewpoints on the nature of eigenstates and their mathematical representations, with no clear consensus reached on the definitions or implications of these states. The discussion remains unresolved regarding the specific characteristics of the eigenstates of the Klein-Gordon field operator.
Limitations include the dependence on specific mathematical frameworks and assumptions about the nature of the field and its eigenstates, as well as the unresolved nature of the relationship between different modes and their eigenstates.
Jonathan Apps
So I've got the field operator for a real, spin-0 field in quantum field theory. Usual expansion in terms of ladder operators and plane wave solutions you'll get in any QFT textbook. What are its eigenstates (ie states of definite field)? It would be similar to the states of definite A-field for quantized EM radiation but without the unnecessary complexity of having vector fields with polarization etc. The states of definite particle number are obviously NOT eigenstates - the expectation value of the field for those is zero. Additionally, what are the eigenvalues? Cheers :-)
As a start, you can try working out a simpler case:
For a 1D harmonic oscillator, what are the eigenstates of ##a+a^\dagger## ?
Got the eigenstates of ##a## - poisson distributed in particle number, so-called "coherent state". It's easy enough to prove ##a^{\dagger}## doesn't have any eigenstates on the space of positive integer particle number. Not sure about ##a + a ^{\dagger}##.
Welcome to PF (I should have written it in #2).
##a+a^\dagger## is proportional to ##\hat X## , so the eigenstates are just ##|x\rangle## . We have$$|x\rangle=\sum |n\rangle\langle n|x\rangle=\sum\phi^*_n(x)|n\rangle=\sum\phi_n(x)|n\rangle$$where ##\phi_n(x)## are the wavefunctions of the energy eigenstates.
Consider now the real scalar field in the Schrödinger picture:$$\hat \phi(\vec{x})=\int \frac{dk^3}{(2\pi)^3}\frac{e^{i\vec{k}\vec{x}}a_{\vec{k}}+e^{-i\vec{k}\vec{x}}a^\dagger _{\vec{k}}}{\sqrt{2\omega_{\vec{k}}}} \quad .$$The ##\vec{k}=0## component is just like ##a+a^\dagger## of the 1D HO, but this time the amplitude of the normal mode 0 (the spatially constant component) takes the role of ##x## above. For the other modes, the reality constraint couples the modes ##\vec{k}## and ##-\vec{k}## , so it is less obvious. Assume that ##\phi(\vec{x})## is an arbitrary real Fourier-transformable function. We want to find the corresponding eigenstate ##|\phi(\vec{x})\rangle## such that$$\hat \phi(\vec{x})|\phi(\vec{x})\rangle=\phi(\vec{x})|\phi(\vec{x})\rangle \quad .$$A nice derivation of the solution can be found at stackexchange.
The referenced derivation (stackexchange) uses the continuum expansion, but relies on the discrete commutation relations ##[a_k,a_{k'}^\dagger]=\delta_{k,k'}## rather than ##[a_k,a_{k'}^\dagger]=\delta(k-k')## . This should be interpreted as some box-like (or lattice) regularization.
Thanks! My Ph.D was on the effective action for various fields on finite spaces - I like the discrete stuff :-) Pretty sure the universe has a brick wall at the end of it somewhere anyway.
  • Haha
We can gain some more insight into the relation between the free field and the 1D harmonic oscillator:
For simplicity, I'll consider the field in one spatial dimension.
The field is real, so we can expand it with ##\cos kx## and ##\sin kx## . Define:$$b_k:=\frac{a_k+a_{-k}}{\sqrt{2}} \quad, \quad c_k:=\frac{a_k-a_{-k}}{\sqrt{2}} \quad.$$In this expansion the coupling between ##k## and ##(-k)## is removed and each "new" mode is truly normal (independent) to the others. This means that the amplitude of each mode (which is a real quantity) behaves like a 1D HO. Sounds abstract, but that is just what we would have expected from a guitar's string if it had only one polarization. We get$$[b_k,b_k^\dagger]=[c_k,c_k^\dagger]=1$$(see remark in #5) and$$[b_k,c_k]=[b_k,c_k^\dagger]=0 \quad .$$Define further$$\frac{b_k+b_k^\dagger}{\sqrt{2}} :=\alpha_k \hat X_{\cos,k} \quad, \quad \frac{c_k-c_k^\dagger}{i\sqrt{2}}:=\beta_k \hat P_{\sin,k}$$where ##\alpha_k## , ##\beta_k## are real proportionality factors. Absorbing ##\omega_k## and normalization factors into these proportionality factors, we have:$$\hat\phi(x)=\sum_{k\ge0} \left( \alpha_k \hat X_{\cos,k} \cos kx+\beta_k \hat P_{\sin,k} \sin kx \right)\quad.$$For a real function ##f(x)## expanded by$$f(x)=\sum_{k\ge0} \left(f_{\cos,k}\cos kx+f_{\sin.k}\sin kx \right) \quad,$$we have$$\hat\phi(x)|f\rangle=f(x)|f\rangle$$where$$|f\rangle=\prod_{k\ge0}|x_{\cos,k}=f_{\cos,k}/\alpha_k\rangle|p_{\sin,k}=f_{\sin,k}/\beta_k\rangle$$(which should be the same as the one discussed in post #4 when ##f(x)=\phi(x)## ). The 1D harmonic oscillator states ##|x\rangle## and ##|p\rangle## correspond to the "generalized" wavefunctions ##\delta(x-x')## and ##\exp[ix(p-p')]## respectively, so ##|f\rangle## should also be regarded as a "generalized" state ( ##\langle f|f'\rangle=\delta^\infty (f-f')## ).
  • Love
In the down direction the universe is known to have stacked turtles.
  • Haha
Are those turtles Neumann or Dirichlet?
  • Haha
  • · Replies 31 ·
  • · Replies 24 ·
